Headers
Old May 24, 2002 | 05:55 AM
tex's Avatar
tex
Question headers
How do I do this
Explain it to me RRRREEEEEAAAALLLLYYYY
S l o w l y ?
Old May 24, 2002 | 06:04 AM
Keith13b's Avatar
Keith13b
Tex, I just edited my last post. Click up a page to it. I hope I explained it okay.
Old May 24, 2002 | 06:55 AM
tex's Avatar
tex
Cool headers
hehe
thanks mate that's bonza!
Old May 24, 2002 | 06:58 AM
tex's Avatar
tex
Cool headers
hey it works!!!
Old May 24, 2002 | 07:00 AM
tex's Avatar
tex
Cool headers
this is the ceramic coated one
Old May 24, 2002 | 07:39 AM
VSsc400's Avatar
VSsc400
2 questions
1.how much is shipping from you to Connecticut USA cheapest method?
2.This will bolt right on right?
Old May 24, 2002 | 08:11 AM
SpoiledBoi's Avatar
SpoiledBoi
Actually, how many of u guys are willing to buy a manifold that bolts to the stockTT that will bolt to the SC....Tex, if u could make us a manifold that would bolt up to the SC head, we could all just buy it... does anyone agree with me?
Old May 24, 2002 | 08:21 AM
awj's Avatar
awj
Bluegr*** Performance
You are referring to a 3.0L 2JZ GE manifold, spoiledboi? That will accept a turbo? Or an aftermarket TT manifold? I would definitely buy a manifold made of high carbon cast iron with a 3/8" flange at mount positions and at least .084" (2-2.5mm) runner thickness. Or a welded piece with high quality welds (316 stainless) that could have some sort of warranty with the same specs. And accept a t60-1.
What do you say?
Old May 24, 2002 | 08:34 AM
VSsc400's Avatar
VSsc400
if its for a 1UZ I am interested.
Old May 24, 2002 | 09:01 AM
tex's Avatar
tex
Cool headers
My system is a straight forward bolt on system, as for any other models it takes money and even more time to make a new header, so it would have to be a group buy, with deposits down 50% only then I would start...
Old May 24, 2002 | 11:39 AM
Lex Luthor's Avatar
Lex Luthor
Hey, Terry. I'm pretty sure we spoke once before a while back, anyway, just curious, the primaries look to be well constructed, did the design of the heads as they are cast above and below the exhaust ports direct you to use that flange design?
- Jon
Old May 25, 2002 | 04:42 AM
tex's Avatar
tex
Question headers
Don't understand what your saying
please explain>>>
Old May 25, 2002 | 07:35 AM
Lex Luthor's Avatar
Lex Luthor
What I mean is that the flanges wrap around the circumference of the primaries and form a small bar laterally to join them together, i'm curious why you didn't form a bar of flat stock to go straight across the flange area, the concern being that with the rate of expansion and contraction of the alloy heads, the flange would have to be pretty significant to keep the assembly from potentially forming an exhaust leak in this area. I'm assuming you adopted this design because of the way the heads are cast around the port area, the oe manifolds/headers use a similar approach, albeit with a slightly wider flange width far as I can tell. Your thoughts Terry?
- Jon
Old May 25, 2002 | 08:55 AM
tex's Avatar
tex
Cool Headers
The main reson for this approach was ease of design, it was an easy design to copy off the oem manifold, as for expansion it is really very minimal, not something we have ever had an issue with because as the head heats up so to do the headers, an being constructed of mild steel it to has an expansion rating not far behind cast alloy.
Did you want a set ?
Regards
Terry
Old May 25, 2002 | 01:53 PM
mjames08's Avatar
mjames08
Default noise..
Will these headers make the lexus a lot louder? I am interested in purchasing a set..
