Problems starting from cold start
Old Jan 9, 2010 | 09:50 AM
nfordhk's Avatar
nfordhk
Default Problems starting from cold start
Hi this problem only occurs from a cold start. I have a video recorded of what happens usually. It use to take 2 tries. 1 Fail then its good. But last night it took 3 tries, 2 fails then it was good im afraid this problem is going to only get progressively worse.
I had my started test said it was good. What could cause this problem
95 sc400 126k. Heres a video I recorded
I feel like this also is the same problem why once in a while when I am not accelerating and hit low speeds of around 15 (coming to a stop) my car will stall (Its automatic)
View My Video
(might need to turn volume up)
Old Jan 11, 2010 | 12:17 PM
nfordhk's Avatar
nfordhk
bump (need longer message)
Old Jan 13, 2010 | 05:31 AM
Dirty SC's Avatar
Dirty SC
wow sounds like the starter but if u had the started tested, then i have no clue. i never herd that sound before. then again i have a 300 not a 400.
Old Jan 13, 2010 | 06:22 AM
Johnny3's Avatar
Johnny3
Sounds like the starter bendix (gear assembly on end of starter motor) is going bad, starter motor runs but doesn't turn the engine. That little gear assembly has an engagement clutch in it & it's slipping (worn out).
alrogers
Feb 24, 2018 09:24 AM
ancdmd
Oct 1, 2013 07:55 PM
lexusnb
Aug 1, 2008 04:31 PM
vtrd00d
Maintenance
May 4, 2005 10:27 AM
Taka
Oct 10, 2002 02:34 PM
