Biggu's engine refresher build thread.
Old Aug 9, 2011 | 09:54 AM
  #196
Biggu's Avatar
Biggu
lol my GF wont ride in the car with me. Apparently randomly flooring it and scaring the crap outta her will make her not want to ride in it. its ok thought, Its not a daily so its all good.
Old Aug 9, 2011 | 10:00 AM
  #197
99SC42's Avatar
99SC42
@Biggu how much line did you buy for your feed line? I can't find an accurate answer some say 18ft, 20ft or 12 haha i am confuse i don't wanna buy to much i don't mind if i am 2-3 feet over but i don't wanna buy too little either .
I just wanna know the length from the back of the back seat to the fuel rail.. do you know or anyboby knows please.
thanks
Old Aug 9, 2011 | 01:54 PM
  #198
94_soarer's Avatar
94_soarer
I feel u bro, i need a Daily driver...after spending so much time n money into my Lexus, i feel i need to get a beater to jus drive around n leave the SC at home...
But one thing i can say about my SC is its one hell of a Daily!!! pretty quick!
Old Aug 10, 2011 | 08:16 AM
  #199
Biggu's Avatar
Biggu
thanks
looks like I ordered 16 foot. Enought to go one way.
Old Aug 10, 2011 | 08:33 AM
  #200
94_soarer's Avatar
94_soarer
So Biggu, i need to replace my Evaporator & Expansion valve could i do it through the glove box or do i have to remove the whole dash???
Old Aug 11, 2011 | 05:33 AM
  #201
99SC42's Avatar
99SC42
Ok thanks so 32feet should do both feeds .. thanks
Old Aug 11, 2011 | 07:39 AM
  #202
DoomLight's Avatar
DoomLight
you should be able to change it out thru the glove box.
cars nowadays u have to do that and take the dash off or 90% to change HVAC related items.
Old Aug 11, 2011 | 08:33 AM
  #203
94_soarer's Avatar
94_soarer
Thanks, i mean im not too sure tho, as i hear u have to take the dash off, & i also hear u can do it through the glove box...
But every pic i seen of the SC with the dash off i cant even see the evaporator n expansion valve...FML
Old Aug 12, 2011 | 06:26 AM
  #204
DoomLight's Avatar
DoomLight
i have a pdf version of the service manual. i'll look for u
Old Aug 12, 2011 | 06:43 AM
  #205
stockhatch's Avatar
stockhatch
Doomlight is right. The manual says to remove the glove box and the cover underneath it. Does not mention anything about removing the dash.
Old Aug 12, 2011 | 08:18 AM
  #206
94_soarer's Avatar
94_soarer
Could you PM it to me
Thanks
Old Aug 13, 2011 | 05:33 AM
  #207
DoomLight's Avatar
DoomLight
the manual is about 55 megs. if you have AOL or yahoo messenger. i could file send it to you. or if u know how to download torrents. i'll give u the link.
Old Aug 18, 2011 | 07:42 AM
  #208
Biggu's Avatar
Biggu
so its been kinda busy buying parts and what not.
SC is still sitting at the shop getting a cage, material is ordered but were just waiting on it to arrive.
in the mean time I have went to the junk yard and got some knuckles and sent them out to Alex at Battle Version to get modified for angle. On top of that I found out my Hydro is hooked up backwards so i will need to change how the lines are run and since im cracking open the brake line and will require to bleed them again. I
ordered my new brake setup.
Supra TT front calipers, Brembo Blanks, Goodridge SS brake lines, Hawk HP+ pads and of course ATE Super blue brake fluid.
rotors are 13 inch compaired to SC stock 11" iirc.
I also found out my harness and helmet are expired so ill need a new harness and helmet along with a new racing suit. FML right.
Old Aug 23, 2011 | 09:28 PM
  #209
Biggu's Avatar
Biggu
So, Cage material shows up tomorrow, along with the modified knuckles, Hawk HP+ pads and I ordered my new steering wheel today.
I also picked up my racing suit today which I kinda fit. looks like its time for a custom suit..
helmet and harness will be here thursday.
it seems like its all falling together!
Old Aug 24, 2011 | 06:23 AM
  #210
stockhatch's Avatar
stockhatch
Sounds good mang Not that you need more power, but I am still curious to see some high boost numbers.
