Steering Wheel Locking during a turn..!!??
Old Dec 10, 2009 | 01:30 PM
Jfg kevin's Avatar
Jfg kevin
Default Steering Wheel Locking during a turn..!!??
Hi, my sc4 steering wheel has locked up on me a few time now during a hard turn. It feels like I completely loose power steering for a split second. The only thing i know to check is to check for leaks in the power steering system, which I have and there is no leak.
Just wondering if anyone else has experienced this before as well and if anyone has any idea of what can cause this to to happen. THX!!
UPDATE (12-17-09)
My steering gets heavy when I'm parallel parking turing the steering wheel back and forth.
Old Dec 10, 2009 | 04:58 PM
GS FONZy's Avatar
GS FONZy
Is the steering fluid greyish? That sounds like a rack and pinion issue. Try flushing the fluid and see if that helps.
Old Dec 10, 2009 | 05:03 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I second that.. Try and flushing the power steering and replace with at least with Dexron III fluid or something equivalent.
Old Dec 11, 2009 | 08:58 AM
fazy_uk's Avatar
fazy_uk
It could also be the steering rack bushes... My first Soarers steering would sometimes become heavy due to this.
Old Dec 13, 2009 | 10:54 PM
Jfg kevin's Avatar
Jfg kevin
Thx for the replies, but i did flush out power steering fluid with auto trans fluid, since i remember reading somewhere that's what it uses...I was gonna do the steering rack bushings later down the road, but i guess i'll have to do it pretty soon..=(..When i lowered my car, my steering did get alot more heavy...
Old Dec 13, 2009 | 11:49 PM
menty's Avatar
menty
Does your dash cut out too? Mine does the same thing. Hows your wiring harness, did you relocate that when you lowered the car?
Old Dec 14, 2009 | 12:02 AM
Jfg kevin's Avatar
Jfg kevin
No, my dash doesn't cut out...and yes, i did relocated the harness...(wasnt fun)..=(
Old Dec 14, 2009 | 12:28 AM
menty's Avatar
menty
Does it lock up over bumps too?
Check that your wheel doesnt touch the wires still, or you may have left out a connector. (its loose)
Old Dec 14, 2009 | 12:41 AM
Jfg kevin's Avatar
Jfg kevin
It doesn't lock up on bumps.....i'm pretty sure all plugs are in...
Old Dec 14, 2009 | 01:07 AM
menty's Avatar
menty
It doesnt, or you dont notice because you are going straight?
Old Dec 14, 2009 | 02:06 AM
Jfg kevin's Avatar
Jfg kevin
..well...I've driven over plenty of bumps with the bad roads around here...It feels fine..I dont understand what your trying to get at...??
Old Dec 15, 2009 | 05:35 AM
menty's Avatar
menty
What else is associated?
I cable tied my wiring and checked all my plugs again.
I still get in association to power steering loss:
- turn signals dont work
- climate control dies
- dash (digital) dies
- boost controller dies.
- no readout on Turbo timer
Headlights function as per normal, and the car still drives. I hit another bump or turn the wheel and it seems to come back alive
Old Dec 16, 2009 | 06:07 PM
menty's Avatar
menty
Did you fix the problem?
Old Dec 17, 2009 | 10:28 PM
Jfg kevin's Avatar
Jfg kevin
Unfortunately no, I have not fixed the problem...But I notice something new about it.. When I parallel parking, and turning my wheel back and forth....i feel it get heavy as i turn it...It feels like the fluid is not gettin pushed back and forth...
Old Dec 19, 2009 | 05:54 AM
menty's Avatar
menty
Is it during a specific turn? I find mine cuts out especially on LEFT turn
