front control arms (interchangeable?)
Old Dec 2, 2009 | 02:49 PM
tuninghaus's Avatar
tuninghaus
Default front control arms (interchangeable?)
are all the front control arms interchangeable between 92-00 SC's? 300 and 400? also including mk4 supras?
the left and right side are specific right?
Old Dec 3, 2009 | 01:41 PM
tuninghaus's Avatar
tuninghaus
reason i ask is my mechanic says a 98-00 is different than the 97 under... that the two models won't fit each other...???
Old Dec 3, 2009 | 04:07 PM
LAVIsH's Avatar
LAVIsH
the supra lca and upper ca will fit i suggest getting supra as there alot cheaper then the oem lexus part im running supra Lca right now on my ride
Old Dec 3, 2009 | 08:40 PM
oneforspaw's Avatar
oneforspaw
does it matter if its supra non turbo or supra TT?
Old Dec 3, 2009 | 09:11 PM
5sp_jzz30's Avatar
5sp_jzz30
supra control are cheaper the lexus. supra control arms have solid rubber bushings while lexus ones are not to make for a very soft, couch-like ride.
supra control arms before 97 were steel. after that they were aluminum. they are also more expensive.
all upper control arms are the same.
all sc control arms are interchangeable.
please do a search next time. this has all been covered before
Old Dec 4, 2009 | 10:00 AM
DKNY0331's Avatar
DKNY0331
lexus wants $500
Toyota wants $300 for the lower control arms. just ask for a 94 supra turbo and tell them u dont have the vin and you dont need a stupid vin there just to lazy to do it any other waywost case scenario get on from ebay,.. i work at a toyota dealership and they still do it to me
Old Dec 4, 2009 | 09:23 PM
5sp_jzz30's Avatar
5sp_jzz30
if your ball joints are still good i can replace your bushings without having to spend an arm and leg on new control arms. i have an extra set of daizen(aka prothane) bushings just laying around. brand new in the box
Old Dec 6, 2009 | 04:26 PM
Son Gokou's Avatar
Son Gokou
You can buy the front lower control arm here for USD$230 each from here:
http://www.l-tunedparts.com/product/?id=3114
I bought 2 front control arms from them when they had on special for USD$199!
Toyota Australia selling the new front LCA each for AUD$1200!
Old Dec 6, 2009 | 04:29 PM
Son Gokou's Avatar
Son Gokou
Oh yer if you decided to do the bushes for the Front LCA, make sure to check the ball joints.
I had changed the Front LCA bushes and after three months, the right hand side front ball joint is worn out!
So i decided to change the front LCA with new ones.
FormosaSC's Avatar
FormosaSC
I'm about the tackle the bushing swap job... I'll let you know how it feels afterward.
Old Dec 9, 2009 | 07:00 AM
rdubious23's Avatar
rdubious23
I'm looking into the LCAs myself and have been reading the many threads on bushings and such. It seems that by the time you buy bushings and ball joints that would you be near the cost of the whole Supra arm ($230), correct?
I've had car for two months (92 SC400), so I'm still getting used to it, but when I had it inspected, LCAs were on the list and I feel the drift when I drive. I would think it makes sense to start fresh with the whole arm.
Is that about right or am I missing something? The mechanics here were trying to screw me when I did my Audi arms so I wanna make sure I'm on point.
Thanks
SC510
May 27, 2014 07:00 AM
thaimonkee
Aug 10, 2009 09:35 PM
jstyles129
Nov 13, 2008 02:19 PM
NoLongerA13bFan
Jan 14, 2008 10:54 PM
SDSC300
Jul 8, 2002 07:53 PM
