2 quick questions
Old Nov 16, 2009 | 12:11 PM
wexpac's Avatar
wexpac
Default 2 quick questions
1.) I have a nasty problem with water getting into one of my headlights and it just sits there all day everyday and will eventually turn it yellow inside out.... how can I prevent this the easier/most efficieft way?
2.) Just was going to the store on about 1/4 tank of gas or less (almost empty) and my car began to bog out and jump when I pressed the gas until for a couple minutes then it warmed up and drove fine... I just bought this car last week and the guy said it might be the fuel pump... you think im fine driving it as it is as long as I allow at least a half a tank of gas in the car at all times? First time happening to me since i bought it but it does also want to slowly die at a idle once in awhile.
Old Nov 16, 2009 | 01:28 PM
turbodremz's Avatar
turbodremz
1.) you will have to open the headlight and clean the inside, then reseal with some good silicone. here for a DIY: https://www.clublexus.com/forums/sc-...finishing.html
2.) 12v fuel mod sounds like a good place to start with what your describing. here again for the DIY: https://www.clublexus.com/forums/per...tures-faq.html
hope that helps out
Old Nov 16, 2009 | 03:22 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Thats should solve both of your problems.
Old Nov 16, 2009 | 05:22 PM
wexpac's Avatar
wexpac
thx! will try to do both of those things tomorrow since its already dark
Old Nov 20, 2009 | 10:57 AM
wexpac's Avatar
wexpac
I asked my mechanic and he said that fuel mod probably woulden't help me out in my situation oh well Does anybody have experience with eBay fuel pumps? I've see nthem going for $80 shipped rather than $375 at autozone or anyone might be able to direct me to a used one somebody may b parting out
Old Nov 20, 2009 | 11:10 AM
FuMoFFuTT's Avatar
FuMoFFuTT
If you're going to get a new fuel pump, you might as well upgrade it. I heard the Denso 255 fuel pumps for the Supra TT are good, especially if you are looking to make more power later on..
Old Nov 20, 2009 | 12:56 PM
t70 supra's Avatar
t70 supra
x2 but thier was some kinda alert on supra forums the fuel pumps on ebay are china made horriable get the supra or stay oem
Old Nov 20, 2009 | 01:16 PM
wexpac's Avatar
wexpac
i see looks like i am going to have to pick up a used one then since there a little pricey... I have absolutly no cash right now and am going to have to borrow the money for a new/used one.... if you kny anybody selling a used one or parting one out dont hesitate to let me know. thanks
Old Nov 20, 2009 | 01:46 PM
codye3m's Avatar
codye3m
pm aliga he can prob has one
Old Nov 20, 2009 | 01:57 PM
t70 supra's Avatar
t70 supra
aliga sells good stuff
Old Nov 20, 2009 | 02:15 PM
wagomaniac's Avatar
wagomaniac
check out the classifides often
Old Nov 20, 2009 | 02:20 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
cmon man, these guys on the forum gave you golden advice on how to fix a known problem. then you asked your mechanic if you should bypass an ecu for free rather than buy a fuel pump ($) and pay to install it (more $). were you really expecting him to agree with information you found on your own that only takes away business from them.
fuel pumps die much less frequently than the ecu. Do the mod, its free, and if it doesnt clear it up get a pump. buy a stock denso or you can go aftermarket with a walboro or other brand. be aware that aftermarket pumps are typically louder than their stock counterparts. I can hear my walboro from inside the cabin whereas I never noticed my stock pump. I have a stock pump laying in my collection of parts box, and after 130k it looks pristine still, those things are quite reliable unless you raise the fuel pressure.
Old Nov 20, 2009 | 02:31 PM
turbodremz's Avatar
turbodremz
your mechanic is a moron, enough said..the links I posted above have been PROVEN time and time again to work and solve issues. Go to Toyota and pick up the factory fuel pump for a MK4 Toyota Supra Twin Turbo, do the 12v fuel mod, stay away from ebay, and from used fuel pumps...
do it right, and you'll only have to do it once
danmm7
GX - 1st Gen (2003-2009)
Nov 8, 2017 10:02 AM
jjbenzo
Jan 4, 2013 11:55 AM
ashtray
Oct 11, 2009 01:43 PM
fju2112
Jan 24, 2008 04:46 PM
