Water Pump replacement?
Old Nov 10, 2009 | 09:40 PM
dejacky's Avatar
dejacky
Question Water Pump replacement?
As I was working on the car (that has been sitting for over 6 months), I noticed what appears to be leaked coolant fluid that came from the water pump. Does anyone know what this symptom means as far as potential problems with the car? Should I replace the water pump and flush out the motor + radiator with fresh coolant?
Old Nov 17, 2009 | 08:21 PM
skgupta24's Avatar
skgupta24
I'd replace the water pump. In just about any car, the water pump is a maintenance item that will need to be changed in the car's lifetime.
Old Nov 17, 2009 | 09:42 PM
vinh's Avatar
vinh
Good lord. it almost looks like bird poop in there. If i were you, i would replace the waterpump/thermostat. While you're in there might as well do the timing belt too
Old Nov 18, 2009 | 01:04 AM
dejacky's Avatar
dejacky
timing belt is fairly new, but i received the new water pump today...doesn't look like a fun job to me!
Old Nov 18, 2009 | 01:37 AM
vinh's Avatar
vinh
it's only fun if you get everything right on the first try haha.
Old Nov 18, 2009 | 05:54 AM
RyanV's Avatar
RyanV
That's really odd you have that much corrosion going on that it's seeping out from everywhere around the pump. It looks like you used tap water that had a s h i t ton of minerals in it to fill it up.
Use distilled water and toyota red coolant and water wetter.
Old Nov 18, 2009 | 05:49 PM
ERXRX7's Avatar
ERXRX7
yeah that crap all over things looks horrible..
Water Pump is not a prob. Just take off stuff like you did when doing the Timing Belt
the WP has like 11bolts/nuts on it other than that you remove the Alt to get to the water neck.
You should be able to bust it out in an afternoon
Old Nov 18, 2009 | 08:24 PM
dejacky's Avatar
dejacky
Toyota Pre-mixed Pink coolant was used .
Old Nov 19, 2009 | 02:17 AM
v8soarer91's Avatar
v8soarer91
If the engine overheated or was getting pretty warm before the car sat for 6 months.
Change the water pump.
May have been slightly warped when you tightened the bolts when installing.
Change water pump.
If it leaked out while it was sitting, the waterpump was not sealed properly
Remove the water pump and reseal with a red goo sealant.
Old Nov 20, 2009 | 10:05 AM
dejacky's Avatar
dejacky
It's a 94 engine, so the water pump was the original one. The replacement process has begun, thanks for everyone's help.
Old Nov 20, 2009 | 10:13 AM
drft_n_VIP's Avatar
drft_n_VIP
where do u stay in texas? if you need help and close the DFW area i could probably come help out
Old Dec 20, 2009 | 03:18 PM
dejacky's Avatar
dejacky
does anyone know what that nipple on the bottom of the newer 2jz-ge water pumps is for? should i just cap it off with a rubber cap and clamp?
Old Dec 22, 2009 | 08:17 PM
TurboB6's Avatar
TurboB6
It's a weep/vent hole.
usermel
Jul 10, 2019 02:18 PM
Steve2424
Jul 28, 2016 12:19 PM
Bocatrip
Jul 4, 2016 04:10 PM
Superfast1
13
Jul 15, 2015 02:46 AM
Sintari
Aug 26, 2007 07:10 PM
