1jzgte 1st start up advise
Old Oct 16, 2009 | 09:51 PM
meangreen1's Avatar
meangreen1
Default 1jzgte 1st start up advise
So this weekend I should be done with swap..... I hope. So from they guys that been down this path before, any good advise is wanted. I like to save time and money, so please help.
Thanks
Old Oct 17, 2009 | 09:29 PM
meangreen1's Avatar
meangreen1
Well anyone? Usually I get at least one smart @ss.
Old Oct 17, 2009 | 11:41 PM
GSXRMack's Avatar
GSXRMack
pull EFI fuse and crank to build oil pressure and uh (cough) make sure the return fuel line is hooked up. Good luck man another 1JZ
Old Oct 17, 2009 | 11:48 PM
shonuff53's Avatar
shonuff53
to add to the line remark ^ after cranking for oil, put the fuse back in and turn the key on without cranking so that the pump gets power and check those fuel connections for leaks, other than that if you did a good job it should start maybe a little bit of smoke after a while its good to go. I just finished replacing my motor a couple weeks ago after blowing the last one. oh yea turn the heater on so the coolant will begin to circulate through the whole system.
Old Oct 18, 2009 | 12:48 AM
GSXRMack's Avatar
GSXRMack
^^Good point on the addons. I didn't have to do the heater because I smashed my heater inlet hose.
Old Oct 18, 2009 | 03:36 AM
$C300's Avatar
$C300
make sure ur coil plugs are secure, they get brittle n brake and dont boost past 12-13lbs with out A/F controller
Old Oct 18, 2009 | 03:46 PM
StiCk3's Avatar
StiCk3
this should be good, although after you plug the EFI fuse back in turn the key to the ON position about 7-9 times to ensure that sufficient fuel pressure is built up. After that cross your fingers and start the car
Old Oct 18, 2009 | 09:37 PM
meangreen1's Avatar
meangreen1
Thanks for all the info. This is worth it's weight in gold!
Brett93ls4
Mar 24, 2019 08:12 AM
MrFairlady
Jul 3, 2018 02:02 PM
hassan86
GS - 1st Gen (1993-1997)
May 17, 2016 06:37 AM
BSC300TT
Aug 18, 2009 08:30 AM
AtlSC300
Jun 16, 2008 11:13 PM
