High beams do not fit snugly
Old Oct 13, 2009 | 11:15 AM
alanchad's Avatar
alanchad
Default High beams do not fit snugly
I just received my 92 sc400 back from the shop after being painted and new lights.
Now I notice that the high beams do not fit snugly into the holes in the bumper. There is a space open at the bottom of the lights, and the alignment bubbles are out of whack.
Is there some adjustment of the lights to make seat better? Other than just the aiming adjusters? Or possibly the bumber could be reinstalled a little off?
Is there any kind of rubber gasket around these as around the low beam assemblies?
I don't want to be **** about this stuff, just spending a lot of money getting this car fixed and want it done properly.
Thanks for any help or insight,
Alan
Old Oct 13, 2009 | 01:07 PM
masagsxr's Avatar
masagsxr
Yeah take the bumper off and check how it sits to the front mounting frame. Mine was so off too and noticed that it wasn't sitting right.
Old Oct 13, 2009 | 01:21 PM
Enigma8246's Avatar
Enigma8246
There is a small metal clip on each one of them that actually clips them to the bumper and pulls them in tight at the bottom. They are not real easy to get to so they may have been left off or just not noticed when they took the bumper off.
The first time i took my bumper off, i didn't take this clip off and when it pulled loose, it shot abt 10' from where i was working.
Old Oct 13, 2009 | 02:41 PM
MarcusMIA's Avatar
MarcusMIA
You have pictures of the newly painted car? How much you pay for it?
Old Oct 13, 2009 | 02:42 PM
GZZ-TT's Avatar
GZZ-TT
Veteran: Army
If I spent a bunch of money on that, I would take it back and tell them they need to align everything, because they didn't do it the first time.* If they say they cant, then speak with the manager, and go from there. If it's a factory bumper, then there is just no excuse whatsoever.
If it's an aftermarket kit, they should have test fit it first at the shop, and done any modifying necissary, like XKnownX's.
Old Oct 13, 2009 | 05:40 PM
ESScee400's Avatar
ESScee400
i'd be taking it back to the shop and making them correct it. just my two pennies.
Old Oct 13, 2009 | 06:04 PM
alanchad's Avatar
alanchad
I will try this weekend to check for the clips and bumper proper alignment.
Also try to post some pics as soon as I can.
I got bumped in the rear bumper and just painted the rest of the car during repair(less top and trunk lid - they were ok).
Thanks again for all replys - folks on this forum are the best.
Alan
Old Oct 14, 2009 | 01:17 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The high beams sit in the header panel and are not very adjustable at all, but you can move them a LITTLE BIT. I've actually gone as far as to remove the frame of the high beams from the header panel and relocate the screws just to get it right..... Nasty little design if it ever gets knocked off just a tad.
Old Oct 14, 2009 | 11:39 AM
SC_coupe's Avatar
SC_coupe
When I got my front bumper resprayed, my driver high-beam didn't fit correctly either. I told them to keep the car until everything fit like factory and they corrected it. Although, compared to a typical car, I'd imagine fitting a front bumper correctly to an SC would be quite difficult. Definitely take it back, if they're a reputable shop they should fix it for you.
huyqly
Jul 30, 2015 09:59 PM
IS250SoCal
Lighting
Sep 8, 2007 03:46 PM
Lyrical
Jan 12, 2005 01:26 AM
idsrvit
14
Nov 17, 2004 10:12 PM
