Factory Tape Player
Old Sep 8, 2009 | 09:30 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Default Factory Tape Player
So, I realized that my 94 SC300 didn't come with a CD player which is understandable since the car is that old. I don't even think they used CD's back then LOL. Anyway, I am SO tired of listening to the radio and I want to listen to my own music. The only way I can think I could do this is by using one of those tape adapter things that have the tape you plug into the tape player on the stock headunit and the cord that comes off the tape and plugs into a audio outlet on a CD player, iPod, etc. Here's my problem though. I bought one of those adapter things and tried to fit it in my stock tape player and it wouldn't fit. Is there a certain size tape that needs to be able to fit in the factory tape player? I thought all tapes were all the same size? Anyone else have this problem?
Old Sep 8, 2009 | 09:34 AM
Ryeno's Avatar
Ryeno
Banned
actually most scs come with a cd changer in the back. You must have a really cheap base model to not have that. Does your sc by any chance have cloth seats and a hardtop(no moonroof)
Anyways the easiest/best thing you can do is buy a metra dash kit and get an aftermarket headunit.
Old Sep 8, 2009 | 09:35 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
By the way - I am going to get an aftermarket navi in my SC soon which will take care of my problems for listening to my own music. But, for right now I want a quick fix while I save up for the navi I want to put in.
Old Sep 8, 2009 | 09:36 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Well, my SC has leather seats, sunroof, everything. The factory headunit has no button for "CD" like other factory headunits I've seen it only has a "TAPE" and radio buttons.
Old Sep 8, 2009 | 10:02 AM
neurocity's Avatar
neurocity
Not quite my tempo
Take a picture of this. Do you even have the connectors in the trunk? (pass side)
Old Sep 8, 2009 | 10:58 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
I don't have any connectors in the trunk that I see, unless they are under the carpet upholstery in the trunk?
Here's a pic of my radio and what I was talking about:
Old Sep 8, 2009 | 12:16 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
in the audio forum i posted how to add an aux input to your standard tape deck.
search for tape hack i think.
Old Sep 8, 2009 | 01:09 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Okay, I will search for that. Thanks.
Old Sep 8, 2009 | 01:17 PM
1siksc's Avatar
1siksc
take a picture of the right side of your trunk.
Old Sep 8, 2009 | 01:18 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Okay, so I just tried searching for your thread and I found it but I am not trying to go through all that. Can't I just used a tape adapter instead? The one I bought doesn't fit my tape player. Is there a specific size tape that fits our factory headunits or are they all the same size? The one I bought was at Walmart, it was a Phillips brand and when I tried putting it in the tape opening on the headunit it didn't fit. It was too long it seemed like. It wouldn't go in very easily...
Old Sep 8, 2009 | 01:20 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Okay, I will.
Old Sep 8, 2009 | 01:39 PM
sbs9's Avatar
sbs9
You're putting it in wrong. or something's broken.
Have you played a tape in it?
Old Sep 8, 2009 | 01:45 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you have to fit it in with the wire side facing towards you. if the wire side faces the headunit, you will have to snake it around the tape in a way that still lets the tape slide in and down, this is very difficult. the bottom of the tape should be facing the right when you put it in the deck (i think, i know it only goes in one way). there is only 1 size of tapes unless you bought it 20 years ago. the one i got from walmart worked, but turns out my tape player wouldnt actually play, lol. so yeah, good luck with that.
Old Sep 8, 2009 | 10:50 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Well, I think my tape player is broken then, because I was definitely putting the tape in there correctly. That was the first time I ever put a tape in there, so I am not sure if the actual tape player plays tapes/works or not. Apparently not though, since the tape wouldn't fit in there correctly, it seemed like it was going in lopsided when I tried. Maybe something is just broken with the tape player on my factory headunit. Oh well I guess I'll just try to hurry and save up for my aftermarket navi I want to put in there lol.
Old Sep 9, 2009 | 06:24 AM
Jeembo's Avatar
Jeembo
Is there already a tape in there? Hit the eject button. My tape adapter works perfectly fine.
Also, that picture you took looks photoshopped . I thought all SCs came with changers. It looks all... lopsided without the CD button.
