please help, R154 transmission
what is this?
http://store.driftmotion.com/static/...hubkitr154.php
is it just like a throwout bearing that comes with clutch kits? im researching/gathering for my upcoming r154 swap on my auto soarer and i am trying to figure out parts inside the tranny...im not mechanically inclined so im doing it step by step
here's what i have that go inside the tranny:
flywheel,
clutch fork, support + spring
clutch kit (pilot bearing, throwout bearing)
please let me know if i am missing anything, it will help me GREATLY, thank you very much!
flywheel,
You will need it, and you'll want snap ring pliers to install the washers too. Might want to get pricing from Curt at Elmhurst Toyota too.
Here's what it looks like installed.
http://img.villagephotos.com/p/2003-...D-IMGP2185.JPG
what is this?
flywheel,
flywheel,
That is the clutch release bearing hub. The r154 is a pull type transmission. This is actually what the throw out bearing attaches to. YOU NEED THIS.
Here is a blown up picture of the w58 clutch (top) with the r154 clutch (bottom)
http://www.cygnusx1.net/Supra/Librar...aspx?S=CL&P=11
Notice how the bottom (r154 pull type) has more components. The hub is the center of it all and it will not be possible to install a throw out bearing if you plan to keep it pull type.
The top (w58 push type) is the more traditional and you would not need a hub for this type of system.
Also, book mark the link. It is the mkIII tsrm. Use it for transmission based assembly instructions. Even though it is for a mkIII, the r154 there is very similar if not the same internally as the soarer transmissions.
One more thing.....Wrong section. This needs to be in the performance subforum.
Good luck.
thank you guys for the great answers. i have another problem, i just found out i can't get the soarer clutch+brake pedel assembly from toyota dealership here...(canada) they said they have no access to it since my car is RHD, so can i get the sc300 pedel kit and make it fit in my car? wats the difference?
Dude, the snap ring is kinda hard to install once all the washers are installed on the hub. It was easiest with someone there to hold it all together while I worked the snap ring....
The wave washer is like $17!!!!!!!!!!!!!!!!!
Deceptively more labor intensive then what you see in the fsm.
AZTurbo
SC400 / 300 Classifieds
Dec 18, 2013 09:08 AM
