Need advice on getting R154 to line up.
So after getting the beast lined up, I can't get the transmission shaft inserted. I would say its about 1-1.5 inches away from seating. I done this before but with no hub sticking out. Anyones past failures or successes are welcomed.
Thanks
Thanks
I always wondered why you can't just install the clutch to the flywheel and then slide the trans in like a push type clutch setup? I was able to just pull the fork off my R154 and then slide the trans off with the clutch still bolted up tot he flywheel, so why can't you install it like that too?
stockhatch I always wondered why you can't just install the clutch to the flywheel and then slide the trans in like a push type clutch setup? I was able to just pull the fork off my R154 and then slide the trans off with the clutch still bolted up tot he flywheel, so why can't you install it like that too?
To answer my own question, I searched and apparently you CAN install it with the clutch bolted to the flywheel in some cars where the bellhousing will clear the tunnel and the flywheel/clutch assembly. I guess most cars will not allow the input to engage the clutch splines before the bell hits the tunnel and everything stops playing nice. It cant be any harder to stab than a W58 if the engine is out of the car...
gte & na-t
gte & na-t
Glad you got everything working.
It is the same as it was before. You can adjust the pedal depth but as far as the feel of your clutch im not sure how you can get it dialed in for your likeing. 2 inches sounds about right for my Stage 2 but now that i think about it it felt more like 3 to 3 1/2 when it was in my Supra. Im not sure ill let you know if it sucks or not when i drift the living hell out of it this weekend
8052JZ
SC400 / 300 Classifieds
04-06-15 08:16 AM
sc1jzgte
Performance & Maintenance
06-01-08 09:27 AM
