Buying used 1uzfe, need advice!!!
Old Jul 26, 2009 | 11:40 AM
toofpik's Avatar
toofpik
Default Buying used 1uzfe, need advice!!!
I have a 92 sc400 with 230k miles on it and the heads are blown... i found an engine for $375 with 94k on it... my question is, should i get the heads on my old engine done or should i go with this newer engine and what should i replace as far as belts and seals? thanx for the help!!!
Old Jul 26, 2009 | 12:03 PM
RedPhoenix's Avatar
RedPhoenix
i would just take the 94K engine as a whole and drop it in...
If you have anything newer on your engine such as a repalced alternator, or something, I would swap that over to the newer engine.
Replace the rear main seal is your main priority. If you see any random oil drips or something, replace those seals...
Matt
Old Jul 26, 2009 | 12:15 PM
toofpik's Avatar
toofpik
Thanks matt!!! i forgot to mention that i bought a head gasket set for my old engine a while back... im thinking that i should go ahead and machine the heads on the engine that im gonna buy and get all those seals replaced... and im gonna change the timing belt, water pump, and the rear seal... are there any sensors that i need to be aware about???
wadge22
May 24, 2016 01:47 PM
chiefnomad
Jan 27, 2016 06:23 AM
wmj259
13
Jan 14, 2016 12:40 PM
Lexus082
Apr 10, 2011 06:46 AM
blessedone
Jan 25, 2011 05:43 PM
