Installing coilovers
Old Jul 22, 2009 | 08:58 PM
QwkSC's Avatar
QwkSC
Default Installing coilovers
I started my Gixxer Drew coilovers install today, The rears are in, But I ended up dropping the LCA's to get the old struts out and the coilovers in, my question is:
Is there any way to get the old struts and the new coilovers in on the front without taking the LCA's out?
Old Jul 22, 2009 | 09:04 PM
5sp_jzz30's Avatar
5sp_jzz30
remove the upper control arms
on the passenger side it is very easy.
driver side is a bit more work since you have to remove the windshield washer bottle, or at least move it out of the way a bit, to get the long bolt out.
Old Jul 22, 2009 | 09:21 PM
QwkSC's Avatar
QwkSC
^thanks for the advice, ya know I probably should have gone ahead and done my bushings I was so far into this.
Old Jul 23, 2009 | 12:03 AM
sc-driver's Avatar
sc-driver
theres a tutorial on how to do it without taking the lca or uca off. You just need another person to push down on the rotors. That's what I did. Don't try this by yourself.
Old Jul 23, 2009 | 03:59 AM
lowkeySC's Avatar
lowkeySC
i did the same thing on MKIV when installing my buddies coils.
Old Jul 23, 2009 | 05:41 AM
Biggu's Avatar
Biggu
take the bolt off top controll arm just leave the ball joint attached.
Old Jul 23, 2009 | 08:18 PM
5sp_jzz30's Avatar
5sp_jzz30
+1 its the easiest way.
some tutorials call for removing the bracket/shock mount from the lower control arm. that is actually more of a pain to do then you think.
Old Jul 23, 2009 | 08:47 PM
QwkSC's Avatar
QwkSC
I had actually thought about that, thanks, I'll just unbolt the UCA tommorow
swong
May 25, 2006 06:40 AM
