Funky Steering
Old Jul 20, 2009 | 04:28 PM
Tony320's Avatar
Tony320
Default Funky Steering
Hey, so I'm having a strange issue with my steering and I was curious if someone here might have an idea.
Normally, when my steering wheel is straight, the wheels point straight. In the last few weeks though, after I take a corner at any sort of speed, the wheel has a tendency to remain slightly turned in that direction after the wheels have straightened out. Turn the wheel to the right, it stays to the right, go left, it goes straight, left again and it stays left.
So I took it into my local mechanic and had him check out the steering linkage and described the problem, and he says everything looks good to him and gives it back to me with no charge.
Any thoughts?
Old Jul 20, 2009 | 04:41 PM
HellFish's Avatar
HellFish
most likely your steering rack bushings. order em up from TM Engineering.
Old Jul 26, 2009 | 02:23 PM
Tony320's Avatar
Tony320
EDIT: So, it was the rack bushings. I asked the mechanic to look at them because I live in an apartment complex that prohibits auto work in the lot. He said he looked at them and they were fine. They weren't. Long story short, I wound up driving the car three hours to my parents house and replacing the bushings myself.
Old Jul 26, 2009 | 05:05 PM
grindin8o8's Avatar
grindin8o8
Originally Posted by Tony320
Thanks for the advice, checked the bushings and they were ok, turned out to be warped rotors. Go figure, couldn't be the cheap fix...
for sure it was the warped rotors? i have the exact same problems and changed my rack bushings but it didn't fix the problem. how do i inspect my rotors to see if it's warped? could it be any other problems?
Old Jul 26, 2009 | 06:41 PM
LEX_MAN's Avatar
LEX_MAN
warped rotors cause pulsation when braking at slower speeds. Let off the brakes and the pulsation will stop.
I dont think rotors would cause wheels to look crooked. Its definitely something with steering. Maybe tie rods, inner /outer ?
JJ823
Feb 9, 2012 11:53 AM
MIGS
Nov 14, 2010 06:25 PM
eh.0728
Mar 5, 2009 01:30 AM
reddlexus
Mar 24, 2007 07:30 AM
GliTCH
Feb 16, 2007 11:10 PM
