Tools for front upper and lower control arms
Old Jul 5, 2009 | 08:13 PM
grindin8o8's Avatar
grindin8o8
Default Tools for front upper and lower control arms
So I wanted to be prepared when I remove my bushings for my front upper and lower control arms and was just wondering what tools would I need to remove and replace the control arm and the bushings? any special tools?
please let me know. btw this is for a 1993 Lexus sc400. replacing it with prothane bushings.
Old Jul 5, 2009 | 08:48 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
There is a bushing tool that you can get at a parts store ,but where you are I don't know where you would go to get it.Here is what it looks like....
http://www.thepartsbin.com/cartools/images/otc-7068.jpg
http://www.leverfamilysite.com/image...ontrol_arm.jpg
The second one is how you would set it up. Just use a socket that is the right size and use a 1/2 inch drive racket. Don't use air tools you could damage the tool or the control arm. The poly kit should come with grease use a lot of it. A vise would also help if you can't do it by hand. If you can't get the old ones out use a torch an heat the outer part where the bushing sits. The rubber should separate and you can then use the tool and don't put the torch on the rubber it burns.lol For some reason you take the castle nuts off the ball joints replace the coder pin.That should be enough info to help you out
Old Jul 5, 2009 | 09:11 PM
grindin8o8's Avatar
grindin8o8
OO thanks. what i really meant, was what tools would i need for removing and replacing the control arms. for example, size? wrench? ratchets? air tools? any needed extentions bars? breaker bars?
Old Jul 6, 2009 | 11:51 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Sockets up to 24 mm if I can remember,impact gun,air rachet,big hammer,wrenches,plyers,. I don't remember all the sizes I haven't messed with the suspension in awhile. Your going to have to find out the rest on your own just remember that to use 6 point metric tools so you don't strip anything out.
Swedish
Oct 4, 2018 04:35 AM
cbgdjg
Jan 26, 2017 04:33 PM
downrigger
Dec 5, 2013 10:59 AM
Lavrishevo
33
Jun 5, 2013 07:53 PM
smarti
Suspension and Brakes
Feb 18, 2007 09:25 PM
