koni yellow question
Old Jun 29, 2009 | 08:08 PM
djb5118's Avatar
djb5118
Default koni yellow question
for those of you that have these shocks, was there modification required to make the shock work properly with the SC?
I have found some stuff online saying you have to drain and cut your OEM stuff to get a measurement to adjust the konis?
any input would be amazing!
-Dan
Old Jun 29, 2009 | 10:41 PM
TheMole's Avatar
TheMole
As long as you use 93-98 supra springs, you should be able to mount them onto your SC chassis.
For damping adjustment, you can refer to the instructions Koni provides here: http://www.koni-na.com/mono.cfm
Old Jun 30, 2009 | 06:19 AM
djb5118's Avatar
djb5118
I realize that, but if you look at this:
http://img.photobucket.com/albums/v3...ctions0005.jpg
it shows that you have to punch, drain, and cut in the install process. Is anyone familiar with this?
Old Jun 30, 2009 | 03:33 PM
TheMole's Avatar
TheMole
No idea man. I have never heard of doing that. Maybe some suspension experts can chime in.
Old Jun 30, 2009 | 07:45 PM
Deepa's Avatar
Deepa
What's illustrated are inserts, which are sort of universal. The koni application for the supra has a perch welded to it. Which means that you put your spring in the stock location.
Old Jun 30, 2009 | 08:40 PM
djb5118's Avatar
djb5118
so it is installed like any other shock?
Old Jun 30, 2009 | 09:07 PM
TheMole's Avatar
TheMole
Yea the koni's are installed like any other shock. Not sure what those instructions were referring to.
Old Jul 1, 2009 | 05:54 AM
djb5118's Avatar
djb5118
Great, thanks guys...
after a little digging I discovered that Koni makes both the regular shocks, but for some applications it is too expensive for them to make a complete housing so they make just the core. If that is the case, you have to cut open your stock strut and install the Koni center. That is what those instructions are referring to I believe.
apVAPES00
Aug 13, 2010 07:07 AM
GS FONZy
Dec 9, 2008 09:10 PM
Nick Lewis
Jul 19, 2008 08:17 AM
jwar
Dec 15, 2002 03:04 PM
