Fuel line sizing(Urgent help)
Old Jun 19, 2009 | 01:19 PM
el maestro's Avatar
el maestro
Default Fuel line sizing(Urgent help)
Im in the middle of a swap and the metal hardline coming from the motor to the fuel filter is damaged and we are trying to run a steel braided line but cannot find the correct size fitting that will go onto the filter.
The problem is that it being metric all we have found are standard sizes.
If anybody has any idea what size fitting will fit on the fuel filter in order to run a braided line let me know!!!!!
Old Jun 19, 2009 | 09:43 PM
lexforlife's Avatar
lexforlife
why would you run a larger braided line and still use stock filter ..
not good
run your braided line from tank and get a aeromotive high flow filter with the correct boss -an fittings for your line size
Old Jun 19, 2009 | 10:41 PM
SC400TT's Avatar
SC400TT
Equivalent braided hose size in AN is -6. I do not know the metric size for the fuel filter, but I would bypass it and add a high end filter, as Lexforlife mentioned.
Ryan
Old Jun 20, 2009 | 07:38 AM
2jzlex's Avatar
2jzlex
To be honest, the more I mess with braided line, the more I hate it. I enjoy myself some neatly done pushlok lines w/ AN fittings. OP you can just use some 3/8 high pressure fuel line if all else fails.
Old Jun 20, 2009 | 07:57 AM
lexforlife's Avatar
lexforlife
actaully ryan stock hardline size is about 1/4in where -6an is 3/8 , i measured it when i decided to run -6an line from the tank to rail i was going to use -8an size which is 1/2 in but felt for my power goals it was overkill
Old Jun 20, 2009 | 01:53 PM
el maestro's Avatar
el maestro
not good
Thanks I Will have to look into that.
The reason is we just wanted a quick replacement since the original line broke.
Old Jun 20, 2009 | 04:08 PM
SC400TT's Avatar
SC400TT
Lexforlife, you are correct. A -4 AN would be about the same size. My bad for the wrong info guys. I bypassed all my hard lines except for the stock return, and ran -6 AN into -10 AN.
Good luck.
Ran
Old Jun 20, 2009 | 08:18 PM
over40driv's Avatar
over40driv
This issue is a very real problem all of us will have to face at some point. Would a high flow filter help clear up any hesitation problems with the 92-95 400s I wonder. I here most of the prob. are more about a weak MAF?
Old Jun 21, 2009 | 05:43 AM
SC400TT's Avatar
SC400TT
Sometimes this will help, depends upon the issue of each individual car. Many malfunctions can cause hesitation. I do think many people do not change out their fuel filters as frequently as they shoud. They SC filters also rust up at the connections quite a bit, so they are real tough to disconnect and replace. So, I don't know the manufacturers suggested intervals, but those shold be followed and checked regularly.
Ryan
wth98sc
May 27, 2014 02:00 PM
1UZFE4ME
Apr 17, 2013 06:37 PM
JAndersson
18
Jun 18, 2012 12:46 PM
