Are these lights even saveable??
Old May 29, 2009 | 11:55 AM
MuGGzyx's Avatar
MuGGzyx
Default Are these lights even saveable??
I have been reading all the threads on here on how to restore the headlights on my SC400 and when I went to look at them last night I noticed that I had another issue. It looks like somehow I have a big melted spot on one of my lenses. Like maybe someone put in the wrong kind of bulb at one point in the past.
I am wondering if this is even save-able if I was to unseal and clean them and polish and all the tricks I have read about on here. Or am I going to be better off replacing them with some OEM units.
Is it possible to replace JUST the outer lense if I pulled and cracked them open?
Old May 29, 2009 | 12:59 PM
mr2tosc4's Avatar
mr2tosc4
As long as there are no cracks on them I'd keep them. Do a search, there are TONS of info on these moisture loving headlights.
turbodremz's Avatar
turbodremz
I would open them up and see how bad it actually is..its amazing what sand paper, and a little elbow grease can fix..
Old May 29, 2009 | 02:45 PM
96SC4's Avatar
96SC4
try and clean 'em up and fix the moisture issue...if it doesn't work or you don't like the way it came out THEN spend the $$$ to get OEM replacements... but atleast try 1st...
Old Jun 10, 2009 | 09:17 PM
FuMoFFuTT's Avatar
FuMoFFuTT
mine went EXACTLY LIKE THIS overnight and I saw it this morning........
Old Jun 10, 2009 | 09:56 PM
lowkeySC's Avatar
lowkeySC
i cant tell how bad the melted part is but if all fails. just get clear lenses (:
Old Jun 10, 2009 | 09:57 PM
gabegtz84's Avatar
gabegtz84
This is a sad part of owning an sc
Old Jun 11, 2009 | 06:28 AM
GZZ-TT's Avatar
GZZ-TT
Someone needs to do some scientific studies to determine the actual thing causing condensation, and then a be-all-end-all FIX.
Some people have theories, but I want tests, data, and facts. lol ... but seriously...
Old Jun 11, 2009 | 09:01 AM
Amini9's Avatar
Amini9
CL Folding 200,000
+1 to UZZ-TT.
Old Jun 11, 2009 | 09:07 AM
ThomasGS4's Avatar
ThomasGS4
Originally Posted by Amini9
+1 to UZZ-TT.
+1 to amini +1'ing UZZ-TT.
Old Jun 11, 2009 | 11:05 AM
Peter_95's Avatar
Peter_95
yup, just gotta re-open, clean and reseal you should be fine.
Old Jun 11, 2009 | 11:26 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Use O.L.T. method of madness. It shows step by step how to do it.
Old Jun 11, 2009 | 12:31 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
if you melted it its probably no good. once you melt plastic it gets a haze throughout.
you would be lucky if its only in the top few layers that you can sand out.
NSeagle78
Lighting
Aug 21, 2009 06:38 PM
dunbar43
Jul 11, 2009 07:34 PM
rottweiler
Northeast
18
Dec 2, 2005 01:06 PM
tommy420
Aug 17, 2004 02:54 PM
CLASSIC
May 17, 2003 08:47 AM
