SC Exhaust Thread
Old Mar 16, 2011 | 09:48 PM
  #181
duanebmorg's Avatar
duanebmorg
Default Top Speed Muffler
I like the sound. Do I understand correctly that everything is stock and only the muffler and tip has been replaced?
Old Mar 18, 2011 | 02:49 PM
  #182
Boergy's Avatar
Boergy
HY!
Yes... all other parts are original, my SC have 3 converters ( i think california edition )
Old Mar 20, 2011 | 06:42 PM
  #183
RX7 RAGE's Avatar
RX7 RAGE
RMM 3" downpipe to 3" y pipe which splits to 3" piping all the way to the 3" vibrant performance mufflers with 4" tips.
Old Mar 21, 2011 | 11:21 AM
  #184
duanebmorg's Avatar
duanebmorg
Thanks Boergy! I am in California and am hesitant to mess with anything that won't pass our strict Smog Laws, but do want to free things up a bit.
Duane
Old Mar 25, 2011 | 02:50 AM
  #185
Boergy's Avatar
Boergy
Duane
HY Duane
it´s not so easy in california to modify?
I install next time as the 3rd catalytic a big 200 cells metal catalytic and a 3" middle pipe. after this, i make a vid and next step the IMF Header and the 2 main catalytics are removed. after every step, i do a emission test to see the values i post all this informations in my SC400 thread
Old Mar 25, 2011 | 12:57 PM
  #186
cjsc400's Avatar
cjsc400
Default please help
I know this doesnt belong on this thread im still tryin to figure out the site. I have no tailights but I have brake lights please someone help me I would do anything but suck another mans stick to fix the problem.
Old Mar 28, 2011 | 12:14 PM
  #187
duanebmorg's Avatar
duanebmorg
Default Boergy Exhaust
California has the most restrictive smog laws in the U.S.A. Cars made in the US are made as 49 state models and Ca. models. If you replace the catalytic converters, they have to be Ca. only parts. FlowMaster makes Ca. only free flowing cats. Technically you can replace anything after the cats and still pass Ca. emission tests. I have seen lots of Ca. cars in this forum with everything replaced from the cats back. None of them have said what happened at their last smog test. I'd like to hear from them.
As I understand it, the cats are high up right after the manifold. The center canister and the two behind the rear axle are resonators designed for the quality of sound. I don't know what is really inside, or how restrictive they are. What concerns me are the many twists and turns, and the squashed pipes under the axle. I would like to free all that restriction up as you intend to do also. Which leads me to pipe size. If the pipe size is too large, high end horsepower is gained, but low end torque is lost. Smaller pipes retain low end torque. For most street and highway driving low end torque will make a car much faster than high end horsepower. The SC400 V-8 has good low RPM torque. What I understand from this forum is the optimum pipe size is 2 1/4". 3" pipe will give you the most H.P. on a dyno test, but will be slower on the street.
Now back to Ca. smog for a quick comment. Recent changes have made cars that easily passed before fail now. Mechanics are recommending changing all filters before a test. Even the smog testers tell you to drive down the freeway for 20 minutes or more to warm the car up really hot. Cold cars fail, hot cars pass. Even a badly sealed gas cap will make a car fail. If I was modifying a recent model car designed for the new regulations, I wouldn't worry. But modifying a twelve year old car with a 20 year old design, concerns me.
Can we hear from California owners that have had recent smog tests?
Old Mar 29, 2011 | 09:15 AM
  #188
Boergy's Avatar
Boergy
From my friend his 92 SC300 with Top Speed Exhaust
http://www.youtube.com/watch?v=wJaHS...layer_embedded
http://www.youtube.com/watch?v=qPXpz...layer_embedded
greets from Austria
Old Apr 11, 2011 | 05:16 AM
  #189
paulwd's Avatar
paulwd
I thought I should add mine since I finally got some video of the Soarer.
Blown V8 with Rush headers and 2 1/4 pipes, twin high flow cats , balance pipe and a couple of free flow no name rear mufflers.
http://www.youtube.com/watch?v=_USP2p5TyYs
Old Apr 16, 2011 | 08:49 AM
  #190
dAng_bAy's Avatar
dAng_bAy
I like RS-R Ex-Mag...! I think if we all email RS-R about making the Ex-Mags for the SC's, they may consider making some...
http://www.rs-r.com/store/pc/contact.asp
Old Apr 20, 2011 | 08:33 AM
  #191
Bott63's Avatar
Bott63
Originally Posted by captcrunch
What's your exhaust setup on this? I like the sound!
Old Apr 21, 2011 | 08:10 PM
  #192
saleens281's Avatar
saleens281
The info on his youtube video just states "mufflers and resonator delete & bosal tips". Thats all. It sounds pretty good.
Old Apr 21, 2011 | 08:37 PM
  #193
k7q's Avatar
k7q
what kind of rims are those??
Old Apr 24, 2011 | 01:05 AM
  #194
paulwd's Avatar
paulwd
The rims are Japanese Wald, mine are 18/8 and 18/9 with a 35mm offset, and they clear big brakes.
Old Apr 24, 2011 | 08:16 AM
  #195
TURBO819's Avatar
TURBO819
Default Replica Boost Logic 4" Downpipe & Midpipe & 4" OBX Universal High Flow Resonator Pipe
Replica Boost Logic 4" Downpipe & Midpipe & 4" OBX Universal High Flow Resonator Pipe With Magnaflow 14834 Race Series Mufflers
OBX Universal High Flow Resonator Pipe (4" to 4" x 26.50") Long. I removed 2" off of each of the ends and had a 4" V-Band added to one end and a 4" to 3" Stainless Steel Reducer which was connected to a Transition Y-pipe 3" Inlet & Duel Outlet
Before 5" was removed. See rear section of Mid Pipe
About 5" was removed from the MidPipe and a 4" V-band was added.
MidPipe & Resonator & Y-Pipe
Plans for the rest of the Exhaust.
Exhaust Clip. http://www.youtube.com/watch?v=wOVNP..._order&list=UL
