quick question about fogs/sidemarkers '99 SC4
Just in case, I wanted to make sure that you understood what INEEDANSC3 wrote. He is saying that in order for you to turn on the fogs, your headlights have to be on as well. You can't turn on the fogs by themselves without the headlights being on. Are your headlights on the on position when trying to turn on the fogs? Hopefully this is the case.
Ok, will a cheap-o multimeter do the trick? I'd have to go buy one, thats why. Also that would only affect that side right? Cause the other side is fully intact and the bulb is good and no dice. What/where is the fuse/relay whatever I should check? Under the hood or in the kick panel?
xxtoobsxx
May 8, 2011 07:59 PM
