Info needed! Please!
Old Apr 18, 2009 | 02:05 AM
sc300guy's Avatar
sc300guy
Default Info needed! Please!
I have a 1992 SC300. Will 20" staggered wheels fit, with out any modifications?
The front wheels are 20x8.5 with a 35 offset, and the rear wheels are 20x10 with a 38 offset.
I'm also thinking of adding an offset of 5mm spacers to both the front and back. Are the spacers even needed?
Old Apr 18, 2009 | 02:31 AM
Hil's Avatar
Hil
You probably need to roll the fenders. Is it stock susp?
Old Apr 19, 2009 | 06:59 PM
SpiderN9NE's Avatar
SpiderN9NE
Post a lil info
up front you should be fine at stock height and lowered, depending on how low you want to go. the rear you will need a roll, probably a good roll if you went any lower than stock. i shaved with 20x10 42 offset and im cranked all the way down on some tein basics. not a severe drop but its enough for twenties. i have the same size and offset up front. before lowering there was slight rub at full turn and a good turn and braking or up hill turn or something with fenderlining. dropped all the way down up front with no front lining i have no rubbing issues unless turning on a bump or incline decline. thats just slight rubbing. i believe a 30 series up front would solve both heights rubbing. maybe even a light narrower tire also. my tires front 245 35 20 rear 275 30 20. i hope this helps.
Old Apr 19, 2009 | 07:27 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
You could check out this sticky @ the top.
https://www.clublexus.com/forums/sc-...300-sc400.html
jmoney6
Oct 24, 2015 12:37 AM
snook
Apr 10, 2009 08:24 PM
YupImJOee
GS - 1st Gen (1993-1997)
Feb 25, 2009 03:39 AM
rfx45
May 22, 2008 08:39 PM
Okay
IS - 1st Gen (2001-2005)
Jan 12, 2007 09:30 PM
