help with which mount to get!
Old Apr 14, 2009 | 09:01 AM
madmax98's Avatar
madmax98
Default help with which mount to get!
just pulled my motor out to drop in a GTE block and found the top portion of my mount completely separated. Is the MKIV mount the right one to get or earlier years are better, i saw somebody in a thread using the mkIII one. Help is greatly apprciated.
Old Apr 14, 2009 | 09:38 AM
Peter_95's Avatar
Peter_95
yo whats up doode..! well, i would post on the performance side for better feedback.. Good luck!
Old Apr 14, 2009 | 09:50 AM
souljah798's Avatar
souljah798
I'm runnin mkiv brackets and mounts
Old Apr 14, 2009 | 12:31 PM
madmax98's Avatar
madmax98
do you have to have the brackets, can i just use my sc brackets?
Old Apr 14, 2009 | 01:32 PM
aliga's Avatar
aliga
Former Sponsor
you can use either bracket with the matching mount.
the newer engine mounts are cheaper than the older mounts.
Old Apr 14, 2009 | 02:42 PM
madmax98's Avatar
madmax98
what exactly do you mean by "matching mounts"? do you mean i cant use the SC brackets with the supra mounts?
Old Apr 14, 2009 | 09:12 PM
madmax98's Avatar
madmax98
news, the SC brackets don't even fit on the gte block i have!!!!
Old Apr 15, 2009 | 04:51 AM
aliga's Avatar
aliga
Former Sponsor
what i meant is the folllowing:
if you have older mounts 93-96, you will need older brackets.
i have a set of older brackets (no mounts). 100 shipped for the pair.
Old Apr 15, 2009 | 12:13 PM
madmax98's Avatar
madmax98
I have a 98 SC300, i also found that passenger bracket is off on one of the holes!
Old Apr 15, 2009 | 02:28 PM
aliga's Avatar
aliga
Former Sponsor
so get the older brackets with older mounts, problem solved.
Old Apr 15, 2009 | 03:21 PM
AngrySC3's Avatar
AngrySC3
What year is your GTE I used stock ge mount and it fit.
Old Apr 15, 2009 | 03:35 PM
madmax98's Avatar
madmax98
it came from pre 98 aristo, i ordered 98 mount and bracket for a supra, hopefully it will work out
Old Apr 15, 2009 | 05:59 PM
AngrySC3's Avatar
AngrySC3
i use stock sc bracket and supra 98 mount.
Dankysc300
Jun 1, 2009 07:08 PM
CDY
Mar 30, 2008 09:42 PM
ridah
Dec 20, 2007 12:36 AM
jbiel
Dec 27, 2005 04:26 PM
CleanSC
Apr 7, 2004 10:00 AM
