Solid Motor Mounts
Old Aug 8, 2007 | 03:28 PM
CDY's Avatar
CDY
Default Solid Motor Mounts
What are the advantages/disadvantages to solid mounts? Are they worth the money on a daily driver that will at most be putting out 500rwhp, or should I just stick with the OEM mounts?
Old Aug 8, 2007 | 06:56 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
stick with OEM mounts... solid mounts are nice and cheap usually, but transfer every bit of engine vibration to the cabin...
Old Aug 8, 2007 | 10:07 PM
CDY's Avatar
CDY
Awesome, thanks for the help! Should I replace the tranny mounts the same time I do the engine? My SC is approaching the 125k mark and to my knowledge none of the mounts have been changed yet.
Old Aug 8, 2007 | 10:21 PM
mitsuguy's Avatar
mitsuguy
it definitely wouldn't hurt anything... its easy enough to do...
Old Aug 8, 2007 | 11:41 PM
zero442's Avatar
zero442
solid motor mounts will make the ride rougher . The cars I've been in with them shook a lotmore than normal. Horse power should improve slightly. Handling should improve noticeably as well since you were running old stock ones. I'm all for it tho. Good luck.
Old Aug 8, 2007 | 11:59 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Rode in my buddies stripped 240 with solid mounts...wow, as a daily i couldn't handle it...WAY too much vibration.
Old Aug 9, 2007 | 09:54 AM
Gunnar's Avatar
Gunnar
Sounds like you should get some TRD mounts. Stiffer than stock but not as harsh as the PHR solid ones.
Old Aug 9, 2007 | 09:57 AM
Blk97SC300's Avatar
Blk97SC300
I'd go with Toyota Supra Mounts (1996+.. the newer ones, NOT the 93-95). Direct replacement, and I believe they're a bit stiffer than the factory lexus mounts. I have these on my car, no complaints at all.
$130 for the pair.. slight discount from the Toyota dealership
Allen
Old Aug 9, 2007 | 10:39 AM
Gunnar's Avatar
Gunnar
Yeah, the 98-spec ones from Toyota dealerships are good too.
I need new mounts as well, not sure if I'm going to go with the 98 ones or TRD.
Old Aug 9, 2007 | 11:33 AM
Bean's Avatar
Bean
Allen, I'm running the same mounts in my car. I got them from the local dealership for the same price
Old Aug 10, 2007 | 08:19 AM
CDY's Avatar
CDY
Thanks again for your help, guys! I think I found the TRD mounts online for $130, am I right?
http://www.injectedperformance.com/V...t.aspx?ID=1455
Old Aug 10, 2007 | 10:27 AM
Gunnar's Avatar
Gunnar
That would be them.
Old Mar 30, 2008 | 09:42 PM
twizted's Avatar
twizted
Its weird that solid mounts give so much vibration in imports i guess its the unibody. I have some moroso solid mounts in my el camino and you cant even feel any extra vibration or anything...
bacardi
Mar 27, 2013 05:45 PM
Dankysc300
Jun 1, 2009 07:08 PM
most
GS - 1st Gen (1993-1997)
Sep 9, 2008 08:38 PM
nicola
Nov 7, 2005 07:22 AM
VSsc400
Oct 23, 2002 08:00 PM
