SC400 Front Caliper problems..
Old Mar 25, 2009 | 12:58 AM
MrWong's Avatar
MrWong
Default SC400 Front Caliper problems..
Looks like my sliding pin on my caliper is seized. I bought the cores but they did not include the other side where the other pad goes..
Anyone have any ideas on how to remove the seized sliding pin? I tried pretty much everything...
Brakes feel like crap since only one side is working properly. The caliper doesn't isn't slide ..
Help plz..
TIA
-Henry
Old Mar 25, 2009 | 07:03 AM
93SC300.'s Avatar
93SC300.
are you talking about the caliper pin that the bolts bolt into or a piston in the caliper?
Old Mar 25, 2009 | 12:44 PM
HellFish's Avatar
HellFish
im pretty sure he means the sliding pin where the caliper bolts too. theres another thread on this. place that bracket in a bench vise. knock that pin out. drench it in some penetrating fluid, let it sit and have at it. if you dont wanna knock it out, use a pair of vice grips and twist. just dont destroy that pin.
Old Mar 25, 2009 | 03:01 PM
MrWong's Avatar
MrWong
Yup it's the sliding pin on the other side of the caliper..
It's pretty seized in there won't budge at all..
No where to really knock away at it = (..
Old Apr 1, 2009 | 12:16 PM
Lexus082's Avatar
Lexus082
I had the same problem about a week ago. I ended up using a propane torch. Worked in 5 minutes. The sliding pin came right out. I couldn't get it out any other way...
Old Apr 1, 2009 | 05:25 PM
davidv433's Avatar
davidv433
if i remember correctly the part where the bolt goes into the pin is a 17 mm nut. pull the rubber boot back a little bit and spray some penetrant in there. then put it in a vise and turn the pin with a socket and a wrench/breaker bar. i had to use my impact gun to turn it on my friends gs400 cus his was frozen too.
Old Apr 2, 2009 | 03:04 AM
MrWong's Avatar
MrWong
thanks guys...I just ended up purchasing new calipers..I removed the eventually but the sliding pin snapped. Even after soaking it for 48 hours with PB Blaster.
Thanks guys for all your help..
carlos
Suspension and Brakes
Mar 4, 2016 05:37 PM
endlesslex
Jun 10, 2014 01:30 PM
morris
Oct 24, 2006 09:14 AM
extremecc
Apr 21, 2003 11:56 AM
