fuel injector cleaner ?
i get the same exact problem.....as well i use the same injector cleaner as its reputable but not very often at all.
sometimes coming to a stop itll seem like its boggin out for a second every once in a great while not a big deal but it seems to be similar to your problem
The injectors are typically flow balanced to less than a 1% variance. When returned, the injectors look new, anything that can be replaced has been replaced, ei. filter baskets, o-rings, pintle caps. The injectors have been tested for leaks, spray pattern, flow rates and subjected to three ultrasonic cleanings and high pressure back-flush to remove particles.
Cost $18 each Witchhunter Performance, who I highly recommend. Worth a read: http://www.witchhunter.com/methods1.php4
There is a before and after photo there and it seriously represents what you can expect.
btw, Witchhunter suggests Techron twice a year for injector maintenance.
