Delima...pease help
iight guys heres my delima...i found out today that my front left brake is leaking. But i dont kno where its leaking from...i havent had the time to jake the sc up and take the wheel off and have someone pump the brake for me to see yet. but ima do it asap maybe in a hour or two...anyway i ordered LS400 calipers,cross drilled and slotted rotors to go with them..and im not sure if my brake line is leakin...so if i do invest in brake lines do i get SS lines for a sc300 or jus get SS for a LS400??? keep this in mind im only doing the front brakes..
if there is what appears to be gunky crap on the lines then it might be the lines. Check the hose connection to the hardline and to the caliper itself. SS lines from an SC3 or an LS4 should work just fine. Also MKIV lines work just as well.
>>>>problem solved got LS4 calipers and rotors
LexAnt
16
Jul 11, 2008 05:08 PM
