Fuel filter
Old Feb 27, 2009 | 07:29 AM
goaliebill's Avatar
goaliebill
Default Fuel filter
A big "heads up" to any high mileage, daily driver SC owners, particularly in Northern climes, where road salt is an issue. Two weeks ago today, I noticed a puddle under my SC400, in front of the driver side wheel well. It was a gasoline leak caused by the corrision and rupture of the metal filter housing which is attached to the frame. It was a steady drip which increased to a stream when the car was running, with pressure in the fuel system.
As it was a long weekend in Canada, I spent three days catching gasoline in an oil drain pan and emptying it into a gasoline can. On the following Tuesday, I had it floated to my mechanic, as I didn't want to risk fire from gasoline running onto the exhaust system. The replacement unit was $ 65 from the dealer, not very expensive in relation to the possible fire hazard if this happened on the road.
Old Feb 27, 2009 | 07:35 AM
VJZ's Avatar
VJZ
Interesting.
Is the 400's fuel filter up front?
Mine is in the back right by the driver side rear wheel well, cleanly marked TOYOTA and then under it: FUEL FILTER.
Kind of obvious eh?
Old Feb 27, 2009 | 07:42 AM
goaliebill's Avatar
goaliebill
Neglected to mention, rear wheel well, same location as the SC300. It caught me by surprise as there is no service recommendation.
381,000 km ( 238,000 miles.)
UZZ30-SC4's Avatar
UZZ30-SC4
Originally Posted by cmiller80
Interesting.
Kind of obvious eh?
the 400's is in the same place
Old Feb 27, 2009 | 07:43 AM
UZZ30-SC4's Avatar
UZZ30-SC4
It should be replaced every 12,000 miles, i recommend more like every 8,000 for optimal performance/mileage. Esp. if you dont use good fuel.
Old Feb 27, 2009 | 10:12 AM
Mr.412's Avatar
Mr.412
thanks folks I will do this today
Old Jul 31, 2009 | 04:04 PM
986ci's's Avatar
986ci's
doing mine tonight, one the way home car just very slowly died, 15 min later started back up then died again 1 block before making it home. going look over a few things thought, but doubt it's been done.
Old Jul 31, 2009 | 04:33 PM
GZZ-TT's Avatar
GZZ-TT
I'm pretty sure this thread should be in the engine/performance forum
Old Jul 31, 2009 | 05:19 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Your right, it should be, but be careful when you loosen those brass connectors on both sides of the fuel filter. Dont strip it out! I replaced mine some ago, and I thought it was on the left rear side of the car, just in front of the left rear tire, and NOT the right side.. Someone correct me if I am wrong. I have a 400.
Old Jul 31, 2009 | 06:42 PM
986ci's's Avatar
986ci's
Yes right in front of the drivers rear tire very easy to get to
ryosuke
Jul 26, 2011 04:59 PM
dinh626
Maintenance
21
Jun 12, 2004 12:11 PM
pimp42
Jun 16, 2003 07:43 PM
indypwr
GS - 1st Gen (1993-1997)
Apr 25, 2003 10:39 PM
