fogs/side markers not working
Old Feb 1, 2009 | 09:48 PM
19ES250's Avatar
19ES250
Default fogs/side markers not working
fellow CL'ers
I pulled my car out of the garage today for the first time this year, my fogs/sidmarkers are not working. Every other light works fine ?? Any ideas ?
cool
Ryan
Old Feb 1, 2009 | 10:09 PM
Amini9's Avatar
Amini9
CL Folding 200,000
fuse?
checkem all
Old Feb 1, 2009 | 10:34 PM
rwdanthony's Avatar
rwdanthony
fuse, wire. you sure you turned them on? lol
has to be one of those. goodluck!
Old Feb 1, 2009 | 10:41 PM
818sc400's Avatar
818sc400
you need new bulbs?
Old Feb 2, 2009 | 05:18 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Buy a bulb first there real cheap. If they don't work check the fuse. Sometimes if you hit something in the road you could cut the wire going to it or pull it out of the plug. If nothing then check for power going to the lights. Use a a voltmeter preferably cause testlights won't give you voltage readings. Check the wiring harnesses and back track them to find any cuts. Also it would be good to check your grounds cause if that gets cut or corrossion on it it won't ground to the body.
AndyWSU
Oct 24, 2013 02:06 PM
dpham528
Dec 14, 2011 12:16 PM
Husni08
Mar 7, 2011 12:56 AM
Durrby
Jul 27, 2009 01:24 PM
rs/ss
Jul 15, 2009 09:14 PM
