Just installed the Zenon 6ooo Volt HIDs for my fogs and they dont seem to work. I checked and rechecked all connections which just consisted of installing new 9007 bulbs and inline wire harnesses.
I checked and rechecked all connections. Is there fuse? It doesnt specify in the O/M. Any other input would be appreciated.
well first of all the fog lights are 9006...second, the fuse for the fogs are in the engine bay driver's side under the plastic panels...third before you check the fuse, swap the original bulb back in one fog light to see if it works..if it works then its not your fuse..
You're correct the bulb is a 9006 and that was a typo on my part. I checked both fuse pannels on pass. side I will check the one on the drivers side. If that checks out i will replace a bulb. Thanks for the fast responce.
so it might be a faulty kit... just for one side that is...
What are the odds of both sides being faulty?
The box was marked Automotive 9007 however the individual bulbs were labled 9006. Is the bulb the only differance between a 9007 kit vs 9006 kit or is the ballast differant?
^^^^i think that might be the problem also...they should put that in the instructions to flip the connector if it doesn't work the first time...it would save a lot of troubleshooting...
if it is the fuse bring it to the dealership. I put mine to stock 2x because the fuse blew. Just put it back to stock. Took me less than 10 mins to take off..
