Oil Pan Question
ok so i have searched, and frankly very frustrated, so please no smart *** search comments or any other crap....
my oil pan is stripped at the plug, and super autobacs claims that it was a standard size, but after they"tried" to rethread it, they said that they did not have the right size...
so i tried to find out on my own what size and what it would take to rethread it..... autozone employees are useless as always, and i wasnt 100% successful in determining the EXACT size.....from what i gathered on my own it is either 7/16ths or 12x1.25mm......
i'm leaning more towards the 12x1.25 since it is japanese and would find it odd that the entire car is metric and to have 1 standard bolt....but someone with they expert knowledge would be helpful....
thanks for the help
thanks for the help
all or most toyota's use the same size drain plug which is indeed a m12x1.25 with a 14mm hex head top for the wrench.
here ya go:
http://www.cgenterprises.com/drain_plugs_metric.htm
if this is not your primary car and you can have it out of commission for a bit i suggest removing the lower oil pan and fixing it. that way you will not get metal shaving or anything like that into the oil and consequently into the motor.
if it is stripped you most likely have some stuff in the pan that should not be there...
here ya go:
i would venture to say less than $100 for a new metal oilpan, probably considerably less- you could ask aliga for a second hand one as well, im sure he has many. unless its bent outa shape really bad from a rock, its most likely not your oil pan that has the issue. its removed with 10mm bolts easily, you just have to re-seal everything which would be kinda icky to do with the motor still in the car
if you are worried about strippage of oil pan, you could install a fram drain or fumitomo drain valve (type thing)
thank you for your response...
now that i have found out super autobacs isnt paying for their mistakes.... does anyone have a pan for sale???
prefer local sellers in so cal...
pm or reply to the thread
thanks
thanks
how are they not paying. thats BS. speak with the store manager and also file with a BBB(better business bureau) if they dont man up.
EDIT: woo hoo 2200th post
ya i think imma do that, u know i wouldnt be so pissed if they just said hey we dont know if it was our fault or someone before, you supply the part and we'll comp the labor...or something along those lines, at least meeting me half way...
My post has little to do with the OP request, but search on "oilpan" brought me here. .. I should have searched "oil pan" ..
Moved to more appropriate thread
Salim
Salim
ChocosLS430
May 19, 2007 03:20 PM
