Climate Control problem
Old Dec 16, 2008 | 07:03 PM
sc3757's Avatar
sc3757
Default Climate Control problem
Ok put a new climate control in cause the old one was stolen a couple months back. Bought it off ebay for $160. Well here is the problem in having. Everything works on it like the lights and the buttons. The only problem in having with it is that when i turn the fan on for heat or whatever, its full blast. Even if its only up one bar. Is it the climate control thats messed up or could it be something else. The last climate control got stolen out of my car so there is no way for me to test and see. Just needed someone's input to see if they hav experienced the same thing. THANKS
Old Dec 16, 2008 | 08:48 PM
0l33l's Avatar
0l33l
Did you get the same year as yours? The 95-96 climate controls are different than the 92-94 & the 97-00 ones.
Old Dec 17, 2008 | 11:37 AM
sc3757's Avatar
sc3757
its a 97. Whats the difference? How would that make the blower not change speeds?
Old Dec 17, 2008 | 12:15 PM
0l33l's Avatar
0l33l
This one's easy. The protocol isn't the same across the years. That's why your CC can do certain functions but not others. However, the faceplate is the same, so those are swappable between the years.
Old Dec 18, 2008 | 03:40 PM
sc3757's Avatar
sc3757
well lol i guess its for sale now lol. Thanks for all of your help
Old Dec 19, 2008 | 03:03 AM
lawrenceO's Avatar
lawrenceO
Just take the new front section (the display part) and mate it with the old rear section (the electronics part) - that will sort it out - don't sell it!
There are instructions to do this on this forum posted by me and others, have a search...
Old Dec 19, 2008 | 03:06 AM
lawrenceO's Avatar
lawrenceO
1. Remove a/c control unit from the car
2. Looking at the rear of the A/C control unit you can see two small screws which need to be removed
3. The front and the back parts of the A/C control unit may now be separated by inserting a flat screwdriver under the lip between the two sections and gently easing them apart, first the top, holding that open, and then the bottom.
4. There are two connectors linking the back section to the front, one white and one brown (in my case), gently remove these from the front section
5. Perform the above for both units (old and new)
6. Mate the new front section with the old rear section
7. Put back into the car
Old Dec 19, 2008 | 03:09 AM
lawrenceO's Avatar
lawrenceO
... and I've just noticed that you say the old unit was stolen, so you can't do this - sorry, should have read your post properly. HOWEVER, you could buy an older, bleeding unit for cheap from a wreckers and do the swap as described.
Old Dec 19, 2008 | 03:17 PM
dwebb99's Avatar
dwebb99
this is good info ,thks
Old Dec 19, 2008 | 04:24 PM
aliga's Avatar
aliga
Former Sponsor
i have the brains from a older year, 60 shipped
LEXZILLA
Dec 14, 2017 07:57 PM
Toptier
May 23, 2007 04:27 PM
