tighter suspension
Old Dec 30, 2008 | 04:22 PM
Mr.412's Avatar
Mr.412
Originally Posted by wheels 2
Yes very much so.I have one blow shock now but if i had some type of coilover or lowering springs with good shocks it would handle like a motherfu#ker.
I bought prothane bushings for my car.But they were a pain in the as# to do.Sense the bushings were 1 or 2 millimeters bigger than the hole you had to put them in.you have to press them it with a vice or a hydraulic press.But it is well worth it in the end.
Before it had so much body roll and now when you turn a corner it doesn't have much body roll.If i had better shocks i would really have no body roll.
Prothane bushings = Tight suspension
how much the poly's cost you and where you get them from?
also did you do front and rear as well as steering rack bushings?
Old Dec 31, 2008 | 05:36 AM
tcrow31's Avatar
tcrow31
Google TM Engineering and buy Daizen poly bushings. They have kits for all the front control arm bushings 99 buck and 150 for the rear and your rack bushing and sway bar bushings range form 30 to 40 bucks.
Old Dec 31, 2008 | 07:09 AM
TougeSC3's Avatar
TougeSC3
Wow. I was just pricing out all of my bushings and it came out to $400 for all of my bushings. That's steering rack, and all the control arms.
Old Dec 31, 2008 | 08:51 AM
wheels 2's Avatar
wheels 2
I bought mine from a guy on eBay.I didn't buy dazien bushings because you have to cut out sleeves and press new ones back in.I bought prothane bushings.I have heard a lot good things about them as well i think i payed right at $400 for every thing control arm bushings front and rear.sway bar bushings tie rod bushings and some other bushings as well.But i do recommend buying dazien steering rack bushings.When i bought the steering rack bushings form eBay it did not come with the round clamp style bushing.But it did come with the other two bushings.So i hope that helps.
Old Dec 31, 2008 | 10:40 AM
Mr.412's Avatar
Mr.412
I'm going to get right on this, also what would you guys suggest I use for suspension components if I’m running 20” wheels?
Old Dec 31, 2008 | 11:47 AM
aalouie's Avatar
aalouie
Also isnt there an adjustment on the steering rack to tighten it? Could try that as well
Old Jan 1, 2009 | 10:52 AM
tcrow31's Avatar
tcrow31
I would start off with the rack bushings and sway bar bushings. The control arm bushings are kinda pita and time consuming. You might be pleased with the result's of just changing out the bushing for those two components.
Old Jan 1, 2009 | 10:55 AM
tcrow31's Avatar
tcrow31
You can also get the dazien with the sleeve already included just 50 bucks more. It really wasn't that much more work to get the sleeve out of the old bushings. just had to press the old bushing out and heat up the sleeve and it slides right out. Ive heard good things about the prothane brand as well.
Old Jan 7, 2009 | 05:05 PM
MEANDAFAKA's Avatar
MEANDAFAKA
bushing, bushing, and more bushing. yeah.
Old Jan 7, 2009 | 06:31 PM
wheels 2's Avatar
wheels 2
Ya but it just seems easier not to put them back in.What do you mean about (Quote)You can also get the dazien with the sleeve already included just 50 bucks more.You dont have to use sleeves in the prothane bushings because the bushings are that much bugger.
fastegg
Jan 31, 2016 10:12 PM
mikobangz
Suspension and Brakes
Jun 9, 2014 08:31 AM
TLcoats
Jan 25, 2011 07:39 PM
gs430rob
Jul 9, 2010 12:04 PM
MPLexus301
18
Jun 22, 2009 09:22 AM
