Maintenance Question...
Old Nov 25, 2008 | 09:09 PM
nate579's Avatar
nate579
Default Maintenance Question...
Okay, My waterpump on the 1jz finally blew it's guts. Thanks to driiftmotion, I purchased the waterpump, timing belt and thermostat, oh and a accessory drive belt. Is there anything else I would need?
I want to get the most out of the stock twins before they go. So I will be keeping the maintenance top notch, and adding a 3" DP, exhaust all the way back and upgrade the injectors. I want no more than 400hp in the car so I when i do go single I am looking at purchasing the Borg Warner S362/S366. Has anyone had any luck with that model turbo on a 1jz. I see them on other engines. Thanks.
Old Nov 25, 2008 | 09:32 PM
OneJay's Avatar
OneJay
You probably also want to replace the timing belt tensioner while you're at it.
Marckussb
Mar 16, 2014 09:19 PM
okula247
Mar 15, 2010 08:28 PM
Tinkler
Sep 29, 2009 07:07 PM
Kaiser
May 20, 2005 08:10 PM
GRIFFIN TT
May 11, 2005 06:27 AM
