Help with 1jz timing belt
Old Mar 12, 2014 | 07:50 PM
Marckussb's Avatar
Marckussb
Default Help with 1jz timing belt
So I've spent the last hour searching for a gates timing belt for my 1jz and all I can find are stores out of Australia.
I've seen the link on here before but I seriously can't find it. Can someone link me?
I know I can go get an Isuzu Rodeo belt, but it also haven't been able to find out which one it is and how safe they are at higher HP. (I'm about to be closer to 500hp)
Thanks in advance
Old Mar 12, 2014 | 08:23 PM
blk&blu*j's Avatar
blk&blu*j
Thanks in advance
www.driftmotion.com stocks them
Old Mar 13, 2014 | 07:32 AM
INTIMAZY's Avatar
INTIMAZY
I know I can go get an Isuzu Rodeo, but it also haven't been able to find out which one it is and how safe they are at higher HP. (I'm about to be closer to 500hp)
Thanks in advance
The Isuzu Rodeo 4ZE1 2.6L belt is more than adequate for our needs. There is NO evidence that it is inferior to the OEM Toyota belt. It spins from idle to redline on their motors same way it does on our cars. HP does not impact this whether the motor makes 100hp or 1000hp.
The only factors that could hasten wear would be aftermarket cam gears, big cams with big springs and maybe a really lightweight flywheel.
Old Mar 16, 2014 | 09:19 PM
Marckussb's Avatar
Marckussb
That's good to know. I am running stock cams with Titan cam gears, hence why I'm interested in the Gates Performance belt, I just can't find it stateside.
okula247
Mar 15, 2010 08:28 PM
Tinkler
Sep 29, 2009 07:07 PM
aswang
Aug 2, 2005 02:56 PM
Kaiser
May 20, 2005 08:10 PM
GRIFFIN TT
May 11, 2005 06:27 AM
