Compressor is LOUD!
Old Oct 15, 2008 | 05:00 PM
RedPhoenix's Avatar
RedPhoenix
Default Compressor is LOUD!
Ever since I had the car, the AC compressor is very loud when its on. The AC works great, its just very loud.
What are my options? Rebuild, new one? or what? Anyone else with the same issue?
Matt
Old Oct 15, 2008 | 08:02 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Find a remand compressor with a lifetime warranty. If you have to buy a new one and it has a lifetime warranty get that if the price is not that much of a difference. Yeah and remember to keep the receipt cause if it does go bad and you don't have it you might be out of luck. When you open the system you need to replace the dryer cause you let the moisture into the desiccant bag. Add another $250 or so to the price tag. Thats my input hope your A/C doesn't give out soon.
Old Oct 15, 2008 | 08:53 PM
YeA 2jZ's Avatar
YeA 2jZ
I have the same noise problem its the clutch assembly on the compressor I tired buying a whole other compressor from a "member" here on CL but never got anything so now I'm just looking for another one so i can have it rebuilt to replace the one i have now... GL
Old Oct 15, 2008 | 08:59 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Yeah I have done the clutch assemblies any they can go good or bad with the install. Those I am sure you need a clutch removal tool kind of like a pulley puller ,but not that close. Yeah those things are never cheap. Especially if you have the old R12 style and want to retrofit the system to R134a. You can put the fittings on ,but the old seal in the lines might have gapes for the R134a to slip by. So in turn you loose the refrigerant faster and you have no A/C. That why I like cars after 95 a couple federal upgrades.
Old Oct 15, 2008 | 11:08 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Mine is a remanufactured one from ebay, and its been in the car for a while now, but its Loud as FUH. Doesn't bug me, when I'm in the car, I don't hear it.
Old Oct 15, 2008 | 11:10 PM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
My bro's Mazda does that....annoying as f***
Old Oct 16, 2008 | 10:03 PM
RedPhoenix's Avatar
RedPhoenix
and it just failed... how ironic...
Old Oct 17, 2008 | 06:54 PM
Luxor's Avatar
Luxor
mine is pretty loud too, I know its about to fail like yours just did. I am guessing it is a bad pulley bearing or clutch assembly.
Old Oct 17, 2008 | 07:55 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
That or the piston inside the compressor is starting to seize up. If and when it does if you don't fix it it locks up and it makes the belt make a crazy squeel. Hope the clutch doesn't go out. Cause if it does that belt will burn till it shreds apart. Replace the whole assembly unless it is just the clutch.
beercan
Apr 17, 2019 05:14 AM
chrisvr6
GX - 1st Gen (2003-2009)
Feb 18, 2018 04:40 PM
levinsoy
Jul 10, 2017 03:38 PM
TLcoats
Aug 2, 2010 01:30 PM
UTSC300
Aug 28, 2007 10:52 AM
