I am having an issue with my driver side window. I repaired the broken wire in the wiring harness and it and the master control switch. So now the window will go up and down partially. The window comes about half way down and for some reason the aft part of the window seems to stop and the front part of the window will go down a little bit more. I don't see anything in the way of the track or what it could be catching on to prevent it from going all of the way down.
The motor sounds find and is NOT making any noises so I don't believe that it could be a motor. It just acts like it is hanging up on something but I can see where.
I did a search on here and read many window issues but I failed to find one that is related to the issue that I am having.
No worries! Good thing I figured this out on my own and such an easy, cheap fix it was. Didn't even need a regulator/motor as many others has suggested.
**Feel free to close this thread since the issue has been resolved.
