97+ spoiler LEDS replace...?
SWEET info ive been wanting to fix this so bad i was gonna buy a aftermarket ebay spoiler with light for like 100bucks jus to get theLED off it if that link i posted didnt work
It is hard to do a how-to on something that varies by spoiler. Not all the same leds burn out on every spoiler, so the problem might be different. I still need to work on mine to figure out why a certain section is not working.
Part of yours is not working because I didn't add enough flux to the solder the wires to bond properly. Let me know when you want me to re-do it.
Guys, the problem with most SC spoiler is that the LED casing itself is not sealed tight. Moisture from humidity will accumulate eventually and rust the LED prongs and such. That was the case with Blkexcoupe's light. Only about 5 LEDs had rusted, but it affected the majority of the LEDs due to the fact that they were wired in in a series/parallel configuration.
For those who are going to rebuild theirs, make sure you put some kind of sealant around the openings. I like those bathroom/window sealants for these kind of projects. Dont get permanent glue just because I said so. LOL.
And yes..Blkexcoupe's spoiler is insanely bright
The place I ordered mine from only had 15000mcd Red leds so I'm gonna have that extra lighting when backing up. The gentleman told me that the shorter prong on the LED is the Negative pole correct? As far as sealant, I'm probably going to use a clear silicone RTV. I'm really eager to fix my spoiler light. My SC is flawless except for the spoiler light. I hope the board is in good shape.
Yes..the negative pole is the shorter prong.
The only real problem with the circuit board is that the metal strip conducting strip from one LED to another is kind of weak. Be careful with it otherwise you might pull it out or even rip it off. In that case you'll just have to use good ol wires to jump it. You'll see when you open it up.
Got my LEDs in and had fun seperating the light housing. GSteg I know what you were talking about, once apart I noticed there was some rust on the power/ground strips. I was able to clean most of it off using alcohol and Q tips. Haven't started soldering the new ones in yet but I'm thinking I'm gonna have to use alot of jumper wires because there are alot of spots where the power strip is missing or appears to be missing. Any other way to repair those power/ground strips besides a bunch of jumper wires?
Using jumper wire is the cheapest and easiest way, other than getting a new board which is probably impossible. I used 20 gauge wiring, only because it was all I had. You can go for 24 gauge if you'd like.
Also, MAKE SURE YOU REPLACE THE LEDS ONE AT A TIME!! they are wired in series/parallel so you gotta make note of each LED's orientation otherwise you may have the LED(s) on the wrong polarity.
Good luck!
Good luck!
