Erratic steering question, im stumped
Old Sep 25, 2008 | 02:25 PM
JDM SC4's Avatar
JDM SC4
Default Erratic steering question, im stumped
Ihave a 96 SC300 w/ 140k on the clock. All stock with no mods what-so-ever. My problem is the alignment. When making a right turn then making the car go straight, the car pulls left and the steering wheel is crooked to the right about a quarter turn.
Here's the weird part, when making left turns, my alignment is straight and steering wheel is level. Any input guys?
Old Sep 25, 2008 | 03:57 PM
sc250tt's Avatar
sc250tt
change lower control bushing and steering reack bushing /.
Old Sep 25, 2008 | 05:21 PM
TheMole's Avatar
TheMole
Try the rack bushings first since they are cheaper, then get an alignment. If problem is still there, look into the front lower control arm/bushings.
Old Sep 25, 2008 | 09:00 PM
StiCk3's Avatar
StiCk3
check the tie rods and ball joints too
hell just check up on the entire front end. The Bushings will help but may or may not solve the problem. Do you have easy access to an alignment rack?
Old Sep 26, 2008 | 03:55 PM
sc250tt's Avatar
sc250tt
Actually this problem plagues the sc .Ive owned 4 of them, some with low miles some with high miles. They were all worn out . Steering rack bushing first and then the front lower and the rear upper. The newest sc is 10 years old now which imo is not a new car. The bushings in these cars are soft which makes it less durable but it does provide a smooth ride. If you can tell me why he needs to replace tie rods and the balljoint i would love to know why.
Old Sep 29, 2008 | 03:02 PM
JDM SC4's Avatar
JDM SC4
thank you so much for your helpful advice sc250tt, but only problem now is to get a source for these items. TM Engineering is MIA..
Old Sep 29, 2008 | 03:09 PM
JDM SC4's Avatar
JDM SC4
also, would it be cheaper if i just swapped out the whole control arms as opposed to just changing out the bushings? If i order new arms, it comes with bushings no? sorry for the questions...
Old Sep 29, 2008 | 03:34 PM
TheMole's Avatar
TheMole
If the front lcas have never been replaced I would suggest replacing the whole arm since they have 140k on them already. You also get new balljoints with the lca so you don't have to worry about them down the line. The 93-96supra front lcas are a cheaper option and bolt right on. Only difference may be the stiffer bushing material.
alteredego
Apr 29, 2012 02:53 PM
talonted
Jun 17, 2010 09:01 AM
k311in
Mar 30, 2009 12:11 PM
basc300
Oct 28, 2008 09:22 AM
milellie11
Mar 14, 2008 06:45 PM
