Steering Rack Replacement Need help. DUI
Old Sep 21, 2008 | 02:48 PM
Lexus082's Avatar
Lexus082
Default Steering Rack Replacement Need help. DUI
I have searched for a few hours and came up emtpy handed. I am working on my 94 SC400 and plan to replace the rack and pinion. So far I have searched and looked in the OEM repair manual and nothing is descriptive enough. I bought a reman. oem rack from Lexus.
Can anyone provide step by step directions on the best method to remove the rack?
I know I have to remove the outer tie end rods, the passenger side bracket and the two driver's side bolts, the two power steering lines, and disconnect the rack from the intermediate shaft.
But, it looks pretty tight as far as accessing the steering lines that connect to the rack. Should I loosen the rack a little to gain more access? I just need a little direction from someone who has done this before.
I have replaced timing belt on this car so the rack and pinion should be cake. This is my daily driver so I don't really have too much time to be under there trying to figure out the best way to remove it. Thanks in advance.
Old Sep 21, 2008 | 03:20 PM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
I think you're looking for DIY, not DUI lol
I don't remember if they have detailed instructions, but you can always check Planetsoarer
Old Sep 21, 2008 | 03:29 PM
Lexus082's Avatar
Lexus082
Thats funny! No time for jokes. J/K, Thanks, i have checked planet soarer. They only talk about replacing the rack bushings which I have already done before.
Old Sep 21, 2008 | 08:59 PM
cbrasian's Avatar
cbrasian
first d/c the arms on both sides crank the wheel all the way to one side then d/c the p/s lines from the rack d/c the electrical connector then take the 12 mm bolt that holds the rack to the steering column (its either 10 or a 12 mm bolt can't remember...then take the bolts holding the rack in place its cake walk
Old Sep 22, 2008 | 08:59 AM
Lexus082's Avatar
Lexus082
I have started to remove the rack. So far I have removed the tie rod ends and started disconnecting the p.s. lines from the rack. Will post updates soon, just getting started...
Old Sep 22, 2008 | 11:13 AM
Lexus082's Avatar
Lexus082
Now I have removed the lines, removed all the mounting bolts that hold the rack on and that 12mm bolt that connects the rack to the shaft. The only problem now is the rack wont separate from the shaft. This is very frustrating and is causing me to spend alot of time trying to remove the rack. The 12mm bolt is completely removed and this damn thing I guess is seized in place. So right now I'm at a stand still....
Old Sep 22, 2008 | 11:22 AM
cbrasian's Avatar
cbrasian
spray some wd40 on it and take your time it will break free btw b4 you remove it make sure to turn the wheel all the way to one side and mark it
Old Sep 22, 2008 | 01:14 PM
TheMole's Avatar
TheMole
You sure you searched?
https://www.clublexus.com/forums/sho...d.php?t=264932
Old Oct 2, 2008 | 08:59 PM
Lexus082's Avatar
Lexus082
Yes I remember reading over that post. I was looking for something with more detailed step by step methods. I will post something with more detail when I have time. I installed the oem lexus rebuilt rack and it was defective and leaking so now I had to put the old rack back on and send the "new" rebuilt unit back to Lexus. Fun...
isospin
Apr 23, 2021 05:25 AM
jim7485
Nov 30, 2015 04:28 PM
DJ8684
GS - 1st Gen (1993-1997)
Aug 10, 2014 02:47 PM
jsimms2
Aug 31, 2013 10:13 AM
redhawks2
Jun 19, 2007 10:28 AM
