Newb tuning question
Old Sep 19, 2008 | 12:37 PM
sneakyazn's Avatar
sneakyazn
Default Newb tuning question
So my car came and it has a greddy emanage and a blitz access ECU among other upgrades. I accidentally left my headlights on and it killed the battery. It was previously tuned before it was shipped to me. Is the tuning already written as hard data or is it wiped out if it loses power etc. Haha, yeah I'm probably using incorrect terms and everything, but I'm just trying to figure out if there is anything I need to take care of after I jumped the car.
Old Sep 19, 2008 | 04:53 PM
TJohnson's Avatar
TJohnson
It should be all stored on the internal memory of the Emanage, which should have its own battery back up if its like any other tuning Ecu i've seen. Only way to know is crank it up and see if it still has all its settings though. I've used the AFC, AFR, MAP ECU, and a few others and they all remember their settings even after being disconnected so I would assume this one is the same way.
Old Sep 20, 2008 | 02:30 AM
cbrasian's Avatar
cbrasian
no there isn't any retuning needed it is stored in the ecu's memory which will not erase when there is no power going to it so jumping it isn't going to damage it nor will draining the battery.... however if you use the jumpers backwards then you'll fry it
Larry96815
Performance
Jul 30, 2014 11:23 PM
Aswilley
Jun 6, 2014 03:39 PM
jdub34
Aug 30, 2007 03:31 PM
joonsta
Jun 24, 2007 04:37 PM
Pianoman72
GS - 1st Gen (1993-1997)
17
Dec 19, 2003 06:09 PM
