Aristo cam swap
Old Sep 12, 2008 | 12:08 PM
DETONATION's Avatar
DETONATION
Default Aristo cam swap
I have a set of usdm cams that I wanted to put in my motor and get rid of the jdms. I know they arent the sickest cams out there but I was wondering if anyone around here has swapped them into there JDM motor around here. I just need help with the shim sizing and lash measurements Im not really familiar with it.
Old Sep 12, 2008 | 04:23 PM
DETONATION's Avatar
DETONATION
Has this been covered here before? I searched but I couldnt find anything
Old Sep 12, 2008 | 05:13 PM
5sp_jzz30's Avatar
5sp_jzz30
if you dont know how shimming cams works maybe you shouldnt be doing the swap. its an easy job and you have to be careful and pay attention while doing it. its easy to get right and VERY easy to get wrong and screw things up.
btw you probably wont find all that info here. supraforums is your best bet.
i would explain it all to you but right now i dont have time and pictures or a phone conversation makes things a lot easier then forum chat.
Old Sep 12, 2008 | 10:31 PM
DETONATION's Avatar
DETONATION
Im sure there was a point in time when you didnt know how to do something as well. That wouldnt discourage me from doing the project I just want to make sure Im educated before hand. And unfortunatly the search function is down so the site isnt much help unless I have hours at hand to read countless threads.
I would asume that I have to:
Measure the lash when the current cams are in and record the data
take them out and measure shim width and record the data
Put the new cams in there and measure the difference in lash
make up for the difference in lash with the right sized shims
done?
Do the cams have to have the same value or gap as the previous?
Old Sep 14, 2008 | 06:11 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
done?
Basically correct, the valve lash (gap) spec is the same. Be generious
w/ the assembly lube.
Old Sep 15, 2008 | 01:18 AM
cbrasian's Avatar
cbrasian
no the shims need to have clearance within spec i have the spec numbers but my toyota manual is at the shop.... btw don't forget to dip the shims in oil b4 you put them in
Old Sep 15, 2008 | 06:53 PM
DETONATION's Avatar
DETONATION
The shims and the bucket assembly?
Old Sep 15, 2008 | 06:58 PM
DETONATION's Avatar
DETONATION
Yeah for sure. I got this german stuff thats suposed to be good
thanks again for the cams!
Old Sep 15, 2008 | 08:39 PM
cbrasian's Avatar
cbrasian
you can take the shims off after you do the cams its a bit tricky but do able very time consuming and yes if you want you can do the shims and bucket in the oil but really jst the shims unless you took out the buckets plus after your done you can lightly dribble oil across the cams and the shims at the same time to keep things nice and lubed
Spoolx
Oct 21, 2018 04:03 PM
S2dannyKeo
Performance
15
Aug 18, 2012 11:20 PM
japspec
Jul 30, 2009 02:17 PM
LeXaNoMicS
Jan 6, 2009 11:03 PM
LeXaNoMicS
Performance
Jan 2, 2009 10:04 AM
