Engine whining? Vid..
Old Sep 4, 2008 | 10:30 PM
vwynn's Avatar
vwynn
Default Engine whining? Vid..
Ok so this has been happening for a long time... so far nothing bad just. annoying. So if i push my car for a bit (not WOT) just accelerating quickly reving up to maybe 4.5k max my car starts to whine, kinda sounds like a supercharger.. just doesnt have the kick of a supercharger..
so yea here is a vid.. dont mind the crusty coolant...been to busy n to lazy to clean it up heh =p
Starter might sound different because i changed it out (OEM starter died) but yea pay attention to a high pictch like whine..
any ideas?
Old Sep 4, 2008 | 11:06 PM
demise77's Avatar
demise77
It sounds like one of your serpentine bely pulleys are going bad. Try removing it and then starting the car. If the sound is gone its one of the pulleys. Try spinning each of the pulleys by and and feeling for resistance, grittiness, or play.
Old Sep 4, 2008 | 11:36 PM
32SC's Avatar
32SC
I had the same noise on my car about a year ago... it lasted a few months and then one day my car started smoking up and it stalled. It turns out that the bearing on my idler pulley was making all that noise and it finally seized and burned up my serpentine belt (hence the smoke)
Old Sep 5, 2008 | 01:42 AM
93sc3005sp's Avatar
93sc3005sp
probly so big deal , love your seafoam vid btw
Old Sep 5, 2008 | 10:03 AM
vwynn's Avatar
vwynn
It does sound like a pulley is going bad... i guess ill go check when i get home. Hopefully i have time.
did ur engine whine when u start it? The vid was taking right after i got home from work. (35 mile drive)
Hah thanks.. sucks that i havent done a seafoam vid with the straight pipe =p
Thanks for the help so far guys!
Old Sep 5, 2008 | 10:50 AM
demise77's Avatar
demise77
It only takes a minute to remove the belt. 14mm to the tensionor and pop it off. If the noise is gone and you suspect a particular pulley to be the culprit. spray some penetrating oil on the bushing and reinstall the belt. If the noise is gone that was the pulley. The noise will only go away for a day or 2 max. def not a permenant fix.
Old Sep 5, 2008 | 11:04 AM
vwynn's Avatar
vwynn
i see i see... i have my eyes on a certain pulley.. but i dont know whats it called.. Its near the AC compressor.. but dam if someone had a picture of the engine bay i could circle it to help..
Old Sep 5, 2008 | 11:09 AM
32SC's Avatar
32SC
I would get the noise on start up and it wouldn't go away once the car was warm. The sound would be drowned out by the engine at ~ 4k rpms though
Old Sep 5, 2008 | 11:16 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
u got a 400 right?
hope this helps, courtesy of Lexls.com
Old Sep 5, 2008 | 11:27 AM
vwynn's Avatar
vwynn
got this pic =p
yea whats the red circle called?
Old Sep 6, 2008 | 10:49 PM
vwynn's Avatar
vwynn
anyone know whats that pulley called? is it a hydrolic pump or something for the fan. O_O
Old Sep 7, 2008 | 03:47 PM
vwynn's Avatar
vwynn
well i spun the pullie that i circled... clockwise and counter clockwise... for some reason theres some resistance going counter... but all the other pullies are buttery smooth...
Old Sep 8, 2008 | 06:00 PM
demise77's Avatar
demise77
on my sc it its the fan pump. Make sure yours also isnt driving the fan. If it is driving the fan then that is what the resistance is from. Did you start the car w/o the belt on to see if the fixed the problem? Also If it does drove your fan check the fluid level for the fan. Make sure its not low. If it is the pump would make a crazy whine like you are experiencing.
Old Sep 8, 2008 | 08:44 PM
vwynn's Avatar
vwynn
is it safe to start the car without the drive belt? and what do u mean it driving the belt? also the problem only occurs when i someone push the car or push the car for a bit... high rev it n such. =/
dimagurr
Oct 23, 2016 10:59 AM
Mar 21, 2016 06:46 PM
vwynn
May 2, 2010 11:51 AM
baboya96
Feb 8, 2008 05:47 PM
ihiryu
Oct 31, 2007 03:03 PM
