Speed Bleeders
Old Aug 27, 2008 | 07:07 AM
CuLayTur's Avatar
CuLayTur
Default Speed Bleeders
I am wondering if anybody has installed a set of the Russell Speed bleeder valves on the brake calipers... I searched and came up with nothing.... I have used them on other car's before and they work great for a one man bleeding operation and since I am rebuilding the calipers, I figured it would be a good addition... BUT, I need to know the correct part number or the correct thread pitch of the stocks to place an order.....
Thanks
Old Sep 19, 2008 | 04:57 PM
JonCAGS300's Avatar
JonCAGS300
Any luck finding them?
Old Sep 19, 2008 | 06:27 PM
5sp_jzz30's Avatar
5sp_jzz30
take your stock bleed screw out, measure the size and pitch, then order. i dont see a complication.
they do work great.
Old Sep 22, 2008 | 03:19 AM
DHBomber's Avatar
DHBomber
Part#639570
7mmx1.0
Good stuff!
Old Sep 22, 2008 | 10:10 AM
CuLayTur's Avatar
CuLayTur
Thanks... It was not complicated... I just wanted to order everything before I disassembled the brakes.... I like to things done fast (if possible).... They are the best and make bleeding jobs a one man task.......
Old Sep 22, 2008 | 04:55 PM
over40driv's Avatar
over40driv
Never heard of them, anybody got a pic. and quick explaination of how they work.
Old Sep 22, 2008 | 07:35 PM
JonCAGS300's Avatar
JonCAGS300
"Russell's patented new Speed Bleeders are the one-man bleeder valves with a stainless steel one-way check ball and spring. Install them in place of the original bleeder valves, and when it is time to bleed your brakes, simply crack them open 1/2 to 1/4 turn and continuously pump the brakes. The spring-loaded check ball opens to let out the old brake fluid and air, then closes between pumps to prevent the old fluid or air from re-entering the brake system. When new fluid starts coming out the Speed Bleeder, all the old fluid is bled from the system and you close the Speed Bleeder down. There is a patented thread compound on the Speed Bleeder that prevents air from leaking past the threads and also keeps the Speed Bleeder from seizing in the caliper. Sold in pairs, Speed Bleeders are available in both metric and standard sizes to fit most vehicles with hydraulic brakes or clutches."
http://www.russellperformance.com/mc...domestic.shtml
The cheapest place I've found them is here...
http://store.summitracing.com/partde...art=RUS-639570
Old Sep 24, 2008 | 04:47 PM
over40driv's Avatar
over40driv
Wow, I wish Id thought of that.
Old Sep 28, 2008 | 05:45 PM
twizted's Avatar
twizted
Ive had them on my car for a couple years now, work well and make it very easy to dump the whole system if you want...
Old Oct 10, 2008 | 02:00 PM
zegnaguy's Avatar
zegnaguy
so what size is needed for our cars and where can you get them?
Old Oct 10, 2008 | 02:07 PM
twizted's Avatar
twizted
I believe they are the same as a non turbo supra, as per speed bleeders site SB7100....
Old Oct 10, 2008 | 04:42 PM
gabegtz84's Avatar
gabegtz84
I like this idea... it'll be important when i upgrade
MannyS
Suspension and Brakes
Sep 29, 2015 11:58 AM
jpw
Jun 2, 2014 05:30 AM
TooCool4u
13
Feb 27, 2013 02:28 PM
dAng_bAy
Aug 31, 2008 01:26 AM
