NEED HELP on CALIPERS!
Old Feb 22, 2013 | 08:44 PM
TooCool4u's Avatar
TooCool4u
Default NEED HELP on CALIPERS!
I have a 2007 IS250 RWD and I want to buy some new calipers but I don't know what is a okay brand name calipers. Or what kind of SPECS I need for my calipers. HEELP! Lol
I need calipers for my stock rotors.
Old Feb 22, 2013 | 09:22 PM
Sffd103's Avatar
Sffd103
Fire Slayer
Do you want a big brake kit?
Attached Thumbnails NEED HELP on CALIPERS!-wheel-pic-dale-tu.jpg   NEED HELP on CALIPERS!-ill-mike-2.jpg   NEED HELP on CALIPERS!-is.jpg
Old Feb 22, 2013 | 09:33 PM
TooCool4u's Avatar
TooCool4u
I just needed new calipers on my stock rotor and I was wondering what other calipers to fit on the stock rotor
Old Feb 22, 2013 | 09:45 PM
Sffd103's Avatar
Sffd103
Fire Slayer
so you want to replace your OEM calipers with another stock size caliper? I don't know about that but I'm sure some aftermarket company makes factory sized calipers. If you want bigger brake calipers, you need to do a complete kit.
Old Feb 22, 2013 | 10:01 PM
TooCool4u's Avatar
TooCool4u
Yeah I want to replace my OEM calipers for another stock size calipers. I'm not looking for bigger brake kit though. Would you know a good aftermarket company for my size and the specs of the OEM stock calipers?
Old Feb 23, 2013 | 09:23 PM
Gville350's Avatar
Gville350
Just get a reman caliper. The company takes your OEM core, fixes everything and replaces everything possible, sells as a new reman caliper for a fraction of the cost of a new OEM unit. Try any online site....AutoZone, Advance Auto, etc etc.
Old Feb 24, 2013 | 08:43 AM
nmpeter's Avatar
nmpeter
Have you looked into getting IS350 calipers? I'm not certain that they work with 250 rotors.
Old Feb 24, 2013 | 04:42 PM
Gville350's Avatar
Gville350
Here's an example of what I spoke about earlier :
http://www.autozone.com/autozone/par...4_410349_2362_
Notice in the pics they show the OEM manufacturer stamping; they're simply reman caliper cores from other IS250s.
Old Feb 24, 2013 | 05:27 PM
flowrider's Avatar
flowrider
Veteran: Air Force
You know everyone's talking to the OP giving both good and not so good advice. But, no one has asked why. To the OP, why do you want to do this? Is there a problem with you OEM calipers? Do you want a caliper with more pad area, more stoping power, more pistons? What exactly is your goal?
Lou
Old Feb 25, 2013 | 12:46 PM
Gville350's Avatar
Gville350
^Though he doesn't necessary state the "why"...he is pretty adament about just replacing them with OE :
Old Feb 25, 2013 | 02:37 PM
skottydznt's Avatar
skottydznt
remanufactured replacement. try partsgeek.com or rockauto.com
Old Feb 27, 2013 | 06:42 AM
TooCool4u's Avatar
TooCool4u
Lou
I just want to find a new caliper so I can powder coat it for looks. And something that fit my stock rotor. I don't know too much about calipers but I just want one that I know will fit my is250
Old Feb 27, 2013 | 08:39 AM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Again, is there a problem with your current rotors? Why can't you just clean and powder coat your stock rotor. Then, there's always those funky caliper covers
Lou
Old Feb 27, 2013 | 02:28 PM
Sffd103's Avatar
Sffd103
Fire Slayer
You can also as suggested upgrade to the IS350 larger front calipers which have 4 pistons and are larger and look much nicer. You can powder coat those or use the G2 caliper paint. You'd probably need the 350 rotors too.
If you just want the same size caliper and to safe you money get the G2 caliper paint and it can be done as a weekend project. Look them up online.
Hoovey689
Jan 25, 2018 12:07 PM
ddvette9
Suspension and Brakes
Sep 23, 2015 01:31 PM
MrGalione9
Dec 27, 2009 08:46 AM
MrGalione9
Jul 21, 2009 07:55 PM
hurricane
Apr 28, 2008 03:50 PM
