Dome Light Doesn't turn off!!! Help!!
Old Aug 20, 2008 | 07:15 PM
tavarish's Avatar
tavarish
Default Dome Light Doesn't turn off!!! Help!!
Hey, I'm having an issue with my dome light.
When I first got the car, I could lock it, and the dome light would dim and go out, like it's supposed to.
Now, I can close all doors, and lock it, and the dome light stays on. Worse than that, the lighted key ring stays on all the time. (i have since taken that out)
I also have a parasitic drain on the battery, and I think it's the trunk light (i have taken that out as well.)
Where should I look?
I need to get this working, as I don't want to have a pitch black car at night, and I would like my key ring light to work.
Thanks,
-Freddy
Old Aug 20, 2008 | 07:49 PM
tavarish's Avatar
tavarish
ok, I've narrowed it down to the integration relay. Who has a pinout of the integration relay?
I have a Service manual for a 95 Supra, anyone know if the integration relays are the same?
Old Aug 20, 2008 | 07:56 PM
Billy305's Avatar
Billy305
You sure it isnt the door sensors?
Old Aug 20, 2008 | 08:00 PM
tavarish's Avatar
tavarish
the dome light and the key ring should go out when I lock the doors, so I'm thinking it's the integration relay. I'll check it this week.
Old Aug 20, 2008 | 08:41 PM
1985zcar's Avatar
1985zcar
Yeah but if your door doesn't "know" it's closed, then they wouldn't go out.
Old Aug 20, 2008 | 08:43 PM
andrewwake's Avatar
andrewwake
is your car lowered? have your tires chewed through the wiring harness? that's one problem I had when I bought mine and once I fixed the wires, viola!
Old Aug 21, 2008 | 08:06 AM
tavarish's Avatar
tavarish
I doubt that's the issue, but I'll take a look. Driver's side, correct?
Old Aug 21, 2008 | 10:15 AM
andrewwake's Avatar
andrewwake
yes, it doesn't sound like the case with yours but it never hurts to check.
Old Aug 21, 2008 | 05:23 PM
tavarish's Avatar
tavarish
I checked, and everything seems fine, nothing was worn down at all.
i have two questions:
Does anyone know if the gauge cluster has anything to do with the integration relay?
Mine is completely rewired, and I'll be redoing the harness again to test for continuity and/or shorts in the harness, since my speedometer doesn't work.
ALSO,
Does anyone have the pinouts of the integration relay?
I know some of you guys have it in your factory service manuals.
Thanks,
-Freddy
Old Aug 21, 2008 | 05:36 PM
davidv433's Avatar
davidv433
dude, if youre ever in hillside stop by my job, id love to see the car. when youre there we can go over to toyota and print out some manuals, and we can clear up some of those gremlins.
Old Aug 21, 2008 | 05:43 PM
tavarish's Avatar
tavarish
actually, I'm in elizabeth, right next to hillside.
I cant drive the car now, waiting on a flange for the blow off valve, and a clutch. PM me your info, and we'll get together and see if we can work this out. if you need any work done, i've worked on this car for about a year, and do pretty much everything. Thanks again, man. I appreciate it!
Old Aug 21, 2008 | 06:48 PM
davidv433's Avatar
davidv433
i work at honda service when you turn right on no. broad in hillside, what color is your car maybe ive seen it b4.
Old Aug 21, 2008 | 07:29 PM
tavarish's Avatar
tavarish
My car's red, but I don't drive it around often. Would you happen to have access to toyota service manuals?
I work on my friend's evo, he lives down the street from you, drives a black evo with rogue motorsport on the side. he was a security guard for the lot across from the honda service dept. a while ago.
Old Aug 21, 2008 | 08:22 PM
davidv433's Avatar
davidv433
i saw a black evo outside today with no front bumper is that him ? ive seen a really clean red sc b4, no windows tints tan interior. and i can have access to toyota service manuals, i have a few friends that work over at toyota service i can just go over and ask them.
Old Aug 21, 2008 | 11:49 PM
tavarish's Avatar
tavarish
nah, mine looks like ****. He def has a front bumper, he has an evo 9.
PM me your number and we can work something out.
Thanks,
-Freddy
