SC400 Sway Bars.
In the front the Supra sway bars are the same thickness as the stock bar on my SC400. They might be slightly shorter but I don't think they'res much difference. Plus the supra bar on the SC400 is pretty dang close to the oil filter.
And after all it's more oversteer that we're after...so leaving the front bar stock and putting a supra bar on the rear will give you more oversteer than both supra bars would.
However, in torquing down the last of the 4 bushing bolts, the head sheared off. Now I've got some bolt extraction to do in tight quarters... Ugh.
I am a bit confused by the front bar specs. I thought I remember reading that the Supra bar is lighter and stiffer, but both are 30mm and the exact same weight ... 9 lb 3 oz vs 9 lb 2.5 oz, well within measurement error and manufacturing variance. Either a previous owner already upgraded my front bar, or the Supra and SC400 bars are identical. Anyone have any insight?
https://www.clublexus.com/forums/sus...-bar-here.html
http://www.google.com/url?sa=t&rct=j...-jFl9K9P8CtWKg
http://www.supraforums.com/forum/sho...ar-differences
It could be that a P.O. wanted to upgrade both front and rears to Supra bars, but the rear was too much work because of having to source the subframe mounts.
Edit: I just checked my removed SC front bar against LEXXIUM's comparison pics and it matches the shape of his SC bar. Now I wish I had checked the Supra bar before putting it on to make sure I wasn't sent the wrong thing...
I only drove the car briefly after swapping bars yesterday, and it did feel a bit different in the corners and over bumps. Less float, but I didn't want to push it too hard with one bolt missing on the front bar's bushing. It may be strong enough to hold like that, with 3 of 4 anchor points... Of course, the one that sheared is the toughest to get to, with all the hoses and hard lines in the way. I'm not sure I can even reach it with the short-ish bolt extraction bits.
The 22mm MKIV TT rear bar I have in mine was substantially heavier than my stock SC rear swaybar and it did make a lot of difference in terms of roll stiffness and rotation potential. The car reacted much better overall after I combined the swaybar swap with an aftermarket suspension however. And the LSD.
The main thing I noticed is that once you switch to an MKIV TT rear swaybar it's better to get an MKIV TT or modified Lance TT alignment to dial the suspension in a bit more. My car was a bit easily tail happy before I changed the alignment. I'm also running staggered tire sizes.
t2d2... that sheared anchor bolt situation up front sucks. I cannot say how safe the car is with one of those missing. Do you think it would be easier to get to with an extractor on a lift?
My driveway is unusable and the street is pretty sketchy for any jacking and working under the car. I had 4 jack stands for the sway bar work, and 2 of them were half tipped over from the lack of a level surface. I have been thinking of taking it by the mechanic to see if they can hit that sheared bolt with some more specialized tools. It's going to be tough to reach with any regular bolt extractor, regardless of whether the car is jacked or on a lift. I've driven lightly on it a couple times with it this way, but need to do something soon.Edit: I got out the ramps and parked the car slightly downhill, which made for plenty of clearance to work. Didn't help much, though, as the sheared bolt is too recessed without major removal of other stuff. I could get to it with a few extenders, but they don't work with my extractor bits, so it's off to the mechanic on Wed.
I also had them take a look at the rear suspension wobble, and they found some worn bushings that need addressing. Not a totally wasted endeavor.
