battery light
Old May 20, 2008 | 12:26 AM
thinhthan's Avatar
thinhthan
Default battery light
hi my battery light lights up. it will sometimes flicker off and on and sometimes turn off for a second or two but most of the time it will stay on. what is causing that to turn on? how can i fix it?
Old May 20, 2008 | 01:16 AM
vinh's Avatar
vinh
get your battery/charging system (alternator) checked out
Old May 20, 2008 | 02:19 AM
SClean4's Avatar
SClean4
battery might be going bad, go to an auto parts store and they can run a test on it.
Old May 20, 2008 | 02:21 AM
xknowonex's Avatar
xknowonex
I'm pretty sure that your alternator is bad.
Old May 20, 2008 | 07:49 AM
Curry's Avatar
Curry
CL Folding 25,000
Check everything said above. Also check your grounds and terminals. This would be a good time to upgrade your grounds.
Old May 20, 2008 | 08:01 AM
amorphous's Avatar
amorphous
I just went through something similar to what you are. My altenator turned out to be bad, I wouldn't say single it out and figure that it is bad, but check and see. If you go to the dealer they can do it for a small charge, they will hook up your battery to a machiene that will measure the voltage from the battery and it will also test the load on the altenator. This will figure if your battery or altenator is bad.
tickter
Nov 24, 2022 09:21 AM
MoeSzyslak
Mar 10, 2014 02:28 PM
lever2000
Jul 30, 2013 08:05 PM
masboy
Mar 4, 2012 06:37 AM
Will400
Chicago Lexus Club
Sep 10, 2005 02:55 PM
