Wtf Ac?
ok. so i went from my 1jz.. to a 2jz... everything is working perfect except now when i hit my AC button. the Idle rises.... but the compressor comes on.. ive checked every fuse i could think of. i bypassed the pressure switch.. when i connect a wire directly from the clutch wire to the battery it kicks on and blows nice and cold.. but hooked up normally i cant get it to come on at all.. any ideas???? btw it worked fine with my 1jz...
Wtf engine and all things related to the engine..... forum?
moved
Haven't messed with the AC much on my car, but seems you need to find the source of the relay trigger and make the corrections needed for it to kick the relay.
moved
i spent an entire afternoon going over wiring diagrams.. and checking stuff.. either im missing something or i have a messed up wiring harness. but correct me if im wrong. the ac clutch wire goes in to the body harness by the fuse box right?
its my 2jz wiring harness.. everything should work just fine.. lol i just dont understand.. i switched out the relays.. and everything. nada. is there something that if its not hooked up the ac wont work??
andy2o3
Nov 14, 2011 12:12 PM
....jus kidding. You are correct. the trigger wire is on the bodyplugs. What harness are you using? Did you do the wiring yourself?
