Has my SC lexus inspected, serious problems?
Old Mar 19, 2008 | 05:39 PM
Erukian's Avatar
Erukian
Default Has my SC lexus inspected, serious problems?
I brought my 92 SC300 5speed down to lexus today to throw $100 at them and have them do their used car safety inspection. They noted these three oil leaks and these are their prices to repair:
1) Valve cover gaskets leaking oil $346.00
2) Cam seals leaking $415.00
3) Distributor O-Ring $145.00
I did the distributor o-ring a week ago so i guess i didn't thoroughly enough clean up the oil because they suspect it's leaking, but there's a little catch-plate under the distributor that i did clean completely and that was previously covered with oil and still no drop of oil has it it yet... so i'm assuming it's still good, lexus must of just saw the oil that dripped on the alternator and thought it was the distributor leaking <shrug>.
I was wondering how serious the first two items are because i can't see that oil anywhere
Any suggestions would be welcome. -Joe
Old Mar 19, 2008 | 06:59 PM
turbodremz's Avatar
turbodremz
any oil in the spark plug valleys? around the upper area of the manifolds? front of the head near the valve covers?
i say clean everything really good, go for a nice drive, then check everything..
not all dealerships are honest..
Old Mar 19, 2008 | 08:25 PM
Danimal's Avatar
Danimal
Valve cover gaskets sounds a little expensive for what it is. With no prior knowledge, using the FSM's I was able to do it in a short weekend with no problems for passenger side. That driver side one is a total (@*#&%(*#&$(#*, I just couldn't get the EGR system off to do everything. Might want to run the car by a reputable independent shop in your area and see what they quote you for it. Good luck!
Old Mar 19, 2008 | 08:56 PM
5sp_jzz30's Avatar
5sp_jzz30
all of those are easy fixes. i did my plugs, distributor gasket, and valve cover gaskets all in about 5 hours...including a LONG lunch, smoke breaks, and a few phone conversations
the cam seals should be along with the timing belt, water pump, thermostat, front main seal, tensioner and idler. they you're all set
btw: dont over look replacing the timing belt idler. they can go bad. the bearings in them start to work really rough. ive seen one seize up too. the tensioners usually work fine and dont need replacement.
there is also the right way and the worng way to install the thermostat. ive done so many toyota/lexus timing belts that i can probably do one in my sleep. lol.
i worked at a shop specializing on toyota/lexus for 3 years until i went off to school.
Old Mar 20, 2008 | 12:35 AM
Mr.NA_T's Avatar
Mr.NA_T
Do It You'r self
It will be fun, and you will learn a little..
So the next time you do it, it will be
Old Mar 20, 2008 | 07:41 AM
Erukian's Avatar
Erukian
is it realistic to do the valve gasket and the cam seal this weekend without pulling out the motor? i'm not sure exactly how to reach back there to change the cam seal.
Old Mar 20, 2008 | 08:05 AM
19psi's Avatar
19psi
you can do all that at home in the driveway engine in the car. sometimes you'll have to wedge you rhand in there to get to soething. you just have to be creative and patient. make sure you have a full set of good tools. don't rush it.
Old Mar 20, 2008 | 08:06 AM
SC4_FI's Avatar
SC4_FI
engine work now goes up on the list of reasons i miss my 240, along with gas O.o
the SC is still wining, btw
SpencerT
Nov 5, 2024 10:16 AM
gsean400
Feb 16, 2023 01:52 PM
Sactolex
Dec 18, 2015 06:00 PM
durtysc300
Apr 27, 2010 04:38 PM
GS300 I6
GS - 1st Gen (1993-1997)
Mar 7, 2010 11:40 PM
